Introduction: Rainbow Loom Feather Bracelet.
Picture of Rainbow Loom Feather Bracelet.
Hello! Here is my first rainbow loom tutorial. I am entering this is the bracelet contest so it would mean a lot if you would vote for me. I've wanted to do a rainbow loom tutorial for a long time but I've been out if supplies for a while and I finally got some new bands. This is an intermediate level bracelet, so if you need help don't hesitate to ask in the comments!!! Enjoy :)
Step 1: Supplies
Picture of Supplies
1.) rainbow loom
2.) rainbow loom hook
3.) 5 different colors of rubber bands
4.) a clip
Step 2:
Picture of
First, take you base removal hook on the end of your hook and remove the bases. Place the middle row so that all of the rows are next to each other. Take your first band and place it going out from the red arrow sideways. Continue a straight row up the left side of the loom. Once you have finished, take one more rubber band and put it into the middle at the end. Repeat this on the right side so that when you are done, it makes a "frame" around the loom.
Step 3:
Picture of
Now we will start with our next color. Take your second color and put it going forward at the beginning of the loom. Now take another color and place that diagonal from the bottom left peg to the end of the black band. Do this on the right side so that it makes an arrow shape. Take your black and make another forward above that arrow shape, and take a different color and make another arrow. Do this until the end of the loom.
Step 4:
Picture of
It should look like this when you have finished.
Step 5:
Picture of
Now we will place the "V " bands. This color will show up the least. To do this, go back to the beginning of the loom and place a band at the first peg in the middle going out and up diagonally as the picture shows. Do this on the other side to make a "V" shape. Continue this all the way up the loom.
Step 6:
Picture of
Now we are done placing the bands. Turn the loom over so the arrow is facing you and place a cap band on the first middle peg.
Step 7: Loopin' Time
Picture of Loopin' Time
To start looping, go under all of the bands and take the top yellow band and place it to the left. Do the same with the right band.
Step 8:
Picture of
For this part, you will not get tear drop shapes for most of the bands for this row. Go under the cap band and take the top red. Place the band onto the left peg it came from and do the same on the right. Then take the last band from underneath the cap band (mine is black) and place that forward.
Step 9:
Picture of
Now you will take the bands on the bottom sides, mine are green, and loop them onto the middle peg.
Step 10:
Picture of
Lastly, take the two side bands and bring the forward
Step 11:
Picture of
Now we will start the actual bracelet. Take the two purple bands on each side and bring them to where the started. Take the black in the middle and bring that up to the middle. Then take the two green bands from the sides and bring them to the middle, and take the yellows on the side and bring then forward. Continue this all the way up the loom
Step 12:
Picture of
Once you have reached the end, you will see there are two yellow bands going inward. Simply take those and bring them towards the middle.
Step 13:
Picture of
Time to finish! Take your hook and stick it through the last pin with all of the rubber bands on it. Take a yellow rubber band and feed that through to make a loop. Now make an extension doing a single chain. Add a clip and pull your bracelet off the loom
Step 14:
Picture of
Almost done! Take your clip and fine the cap band in the other side and attach them.
Step 15:
Picture of
Enjoy your feather bracelet!! Let me know in the comments if you need help and I will make sure to help you. I hope you enjoyed this instructable and I also hope I didn't confuse you too much. Thanks for viewing!
marionpixie (author)2014-01-06
Hello, I was just wondering if I could add some of the cool things you make to the collection I am making? the reason is that I love the things you make.
mclare50 (author)marionpixie2017-07-02
Sure!
ilovedisneyfrozen (author)2014-04-17
Yay! It worked out so great! Easy steps :) love it! you should really make more tutorials!
Thank you!
dixiegirl990 (author)2014-05-22
I made it
mclare50 (author)dixiegirl9902017-07-01
Love the colors!
PhatGurlCandi made it! (author)2015-02-19
didnt have a loom with a detachable base so had to do it with offset pegs. turned out pretty good tho
mclare50 (author)PhatGurlCandi2017-07-01
Oh wow! I like that
ilovedisneyfrozen made it! (author)2015-04-23
Awesome!!!! Thank you!!!! Here is my picture but I took it with my kindle so, goodbye high resolution :)
So cool! Love it
Loomster1 (author)2015-05-16
awsome girl
mclare50 (author)Loomster12017-07-01
Thanks!!! :)
Loomster1 made it! (author)2015-05-16
made it love it I had some ripped bands but no biggy
So cool!!! Thanks for sharing
sakthipikku (author)2015-09-03
I can't get it after step 6 can u pls show clearly with the rainbow loom hook clearly?
koala2711 (author)sakthipikku2017-03-10
If you can't get past step 6 you're obviously a beginner and need to do a different bracelet because it clearly says this is a intermediate bracelet. What step 7 is having you do is a basic hooking method that you do in almost all bracelets
shevanka horan (author)2016-02-26
wow thats cool....
Evelyn 123 (author)2016-01-04
When I loom it it doesn't look the same as yours can you help me out p
totally love this
onedirectionlovelouis (author)2015-05-02
I made it it is awesome
Loom Rocker (author)2015-04-30
cool am going to try it
MahaQ (author)2015-02-07
I can't get it right ??tell me what to do ?after step 6
s4nity (author)2014-06-02
sunshiine (author)2014-03-16
Yay! You won! Awesome!
mclare50 (author)2014-03-12
I sure will! I'm in class right now :) but I'll definitely message you when I'm home
queenbee678 (author)2014-02-07
Thank you. Simple step by step. Great work!
Pretty!!!
ilovedisneyfrozen (author)2014-03-04
I got to Step 11,... could you private message me and tell me how maybe with pictures? thx
DIYbracelet and happyloomlover ( message diybracelet )
T-BONE3 (author)2014-03-03
Soooooo hard
nkephart1 (author)2014-02-23
Your tutorial was really good and easy to follow but how can i get my rubber bands to stay tight i have like six or seven that's loose
mclare50 (author)2014-02-22
Marshmilla you need five colors, but they could totally be the same colors
Queenbee678 that's so pretty! Nice job!
Kelseylynn1 as long as the loom is the same configuration as a Rainbow loom
marshmilla (author)2014-02-22
i luv this bracelet it is soo purdy! but do u really need five colors?
kelseylynn1 (author)2014-02-10
Does it work on any other loom?
sunshiine (author)2014-02-01
Wow your making some impressive instructables! Thanks for sharing your hard but fun work.
sunshiine
mclare50 (author)2014-02-01
Thanks so much sis1424!! It really means a lot to get such positive feedback from people, thanks for viewing!
sjs1424 (author)2014-01-30
This is great. I made a rainbow pattern. It looks great. LOVE IT!!!
mclare50 (author)2014-01-14
I use patterns I already know and combine them with different ones to make things like this, but this was actually originally created by rainbow loom
Cutegirlbaby (author)2014-01-13
that is so cool where do you get your rainbow loom ideas from?
mclare50 (author)2014-01-07
That's beautiful furby1316
marionpixie (author)2014-01-07
thank you so much mclare50
furby1316 (author)2014-01-06
This is the one I made
mclare50 (author)2014-01-06
Of course!! Thank you so much I'm flattered, you're really so kind. Add anything you want! xoxo
bobferret14 (author)2014-01-04
My one side didn't turn out right. It just fell apart.
changed_up_01 (author)2013-12-30
What is the underneath supposed to look like
mclare50 (author)2013-12-28
Thanks furby1316!! Show me a picture if you make one :)
furby1316 (author)2013-12-27
This worked great.
mclare50 (author)2013-12-23
Joann- wow it looks amazing!!! Wonderful job, thanks for sharing!! xox
marionpixie (author)2013-12-23
thank you for letting me know about the knockoff loom
About This Instructable
212,144views
291favorites
License:
Bio: Hi there! nails and jewelry are my favorite area to make instructables on. i love plants, my dog, and the beach :)Thanks for viewing!!
More by mclare50:How I Fixed My WatchWispy Nail ArtOlympic Rings Rainbow Loom Tutorial
Add instructable to:
