Introduction: Rainbow Loom Rings
Step 1: What You Will Need
You will need :
1 - loom
12 - bands
1 - s clip
1 - hook
Step 2: Placing the Bands
Start from the middle point at place that band forwards.
Then do the same once more.
Step 3: Placing the Bands
Then from the the third middle point get a different coloured band and place it to the left.
The get the same coloured band and from the third left point up place the band and then place it up.
Step 4: Placing the Bands
Then place a band from the fifth point to the middle point to the right
Then repeat so it will look like the picture
Step 5: Placing the Bands
Then put two band from the fifth to sixth and sixth to seventh middle point.
Step 6: Placing the Bands
Then go to the fourth point on the left to the third point to the right and then on the third point on the left to the fourth point on the right to look like the pictures.
Step 7: Looping the Bands
Turn your loom around and start looping
Step 8: Looping the Bands
So once you have turned your loom around you now need to go to the second point closeted to you and loop it to the third point
Step 9: Looping the Band
Then you are going to get the top pink band and loop It to the left
Step 10: Looping the Bands
Then you are going to grab the same colour band and loop that up
Step 11: Looping the Bands
Then from where you looped that band you are going to grab the same colour band and loop that back to the middle and then repeat on the other side
Step 12: Looping the Bands
Now that you have done both sides you are going to grab the band that will go around your finger so for me that is sparkly pink and I am going to loop that up and then do that again with the other band
Step 13: Putting on the C or S Clip
So now grab your c or s clip and hook it on to the first band
Step 14: Pulling the Ring Off
and the take it off and hook the s or c clip to the last band
Step 15: Finished Product
So now you should have a ring :) thanks for reading my tutorial and please leave a comment telling me how you went with making it thanks :)
