Rainbow Loom Starburst Bracelt
31,202
21
9
Published
Introduction: Rainbow Loom Starburst Bracelt
To make the Rainbow Loom Starburst Bracelet you will need:
-1 Rainbow Loom
-1 C clip
-Multiple rubber bands of various colors
Step 1: Placing the Bands
Start with the Rainbow Loom facing in the direction where the red arrow is facing away from you. Take a rubber band and place it from the center pin to the left and continue up the loom. Start from the beginning and do the same on the right side. The finished step is shown in photo #2
Step 2: Placing the Bands
You will now be placing the bands in a counterclockwise direction.The first band will be placed from the second middle pin to the right second pin. The second band will be placed from the center pin to the first peg on the right. The third band will be placed vertically from the center pin to the first center pin .The fourth band will be placed from the center pin to the first left pin. The fifth band will be placed from the center pin to the second left .The sixth band will be placed vertically from the center pin to the third center pin.
** Continue up the loom!
Step 3: Placing the Bands
Your loom should look like this:
Step 4: Placing the Bands
Place a cap band on each of the centers of the "sunshine shaped" band formations and the last bands on the end. Do so by doubling the band by folding it upon itself.
Step 5: Looping
First, turn the loom around. Pull back the cap band on your center pin and loop the first band forward. You will now be looping the bands in a clockwise direction. Put your hook inside all of the bands in the center and loop the second, third , fourth, fifth, and sixth bands from the center to the outside corresponding pins. Continue up the loom.
Step 6: Looping
Step 7: Looping
Loop the outside bands by pulling the cap band back. Continue on both sides all the way up the loom.
Step 8: Finishing
Now that you are done looping you are ready to put your hook through all of the bands on the end and put a band through them all. To make an extension, place bands up one side of the loom until the second last pin.  On the last pin, place the bracelet on the loom, flip the loom around and loop back.  At the end place a c clip.
  • Stick It! Contest
    Stick It! Contest
  • Pets Challenge
    Pets Challenge
9 Comments
Your very slow its so easy so help yourself
hay thnx so much friend started showing me but didnt have time 2 finish
its soo hard i follow but it all turns out wrong :'(
Wow! That looks so complicated.
