Introduction: Rainbow Loom Triple Single Advanced
Step 1: Loom Set-up
Set up your loom so that the rows are in the shape of a "v".
Step 2: Banding
Take a colored band and take it from the bottom peg and stretch it up to the beg right above it. Do the same on all of the bottom pegs.
Step 3: Color Banding
Continue doing the same thing all the way up the loom.
Step 4: Center Banding
Take a neutral color and, skipping the first set of pegs, place it on the loom so it looks like an upside down triangle.
Step 5: Begin Hooking
Make sure the arrow is pointing towards you when you begin hooking. Take the bottom colored band and pull it up to the peg directly above it.
Step 6: Continue Hooking
Do the same thing on all of the rows above the first one until you reach the end if the loom.
Step 7: Finishing the First Half
Attach an s-clip ( c-clips work too, but they come off easier so I recommend s-clips ) to the ends of each row. Then remove the half and very carefully set it off to the side.
Step 8: The Second Half
Do the same thing you did for the first half up until the hooking. The only difference is that you don't put a center color band on the fort or last peg.
Step 9: Connecting the Halves
If you follow the pictures, then it should turn out right.
Step 10: Completely Connected
After they are all completely connected, continue hooking like you did on the first half.
Step 11: Almost Done
Carefully remove the bracelet from the loom up until the last row as shown in the picture. Hater the bands on the top left peg and move them over to the top middle peg. Do the same with the top right peg.
Step 12: Attaching a C or S Clip
Put a neutral color through the bundle of colors and take a clip and attach it to both ends.
Step 13: Finished
If it looks like this, then you're done.
Bracelet Contest
