Rainbow Loom Triple Single Basic
54,640
38
5
Published
Introduction: Rainbow Loom Triple Single Basic
Step 1: Set-up
Set-up your rainbow loom so that the pegs are in rows shaped like "v"'s, not straight.
Step 2: Starting
Take a color band of your choice and take it from the bottom left peg to the second left peg. Then, do the same from the bottom center peg to the second center peg. Then the same from the bottom right peg to the second right peg. Continue this all the way up the rainbow loom.
Step 3: So Far
This is how it should look so far. If it doesn't look like this, go back and start over.
Step 4: Center Bands
Flip your loom around so that the red arrow is pointed towards you. Take a color that you haven't used yet,(I typically use either black, white, or dark blue) and put it around the bottom three pegs. Do the same all the way up the loom, skipping the last row.
Step 5: Hooking
Take your hook and put it through the center band and grab the colored band. Pull that colored band to the peg above it. Do that all the way up the loom on all three rows.
Step 6: So Far
This picture is upside down, but if you flip it, this is how it will look so far.
Step 7: Finishing
Gather all of the bands on the top left peg and put them on the top center peg. Then take the top right bands and do the same.
Step 8: Finishing
Put your hook through all of the bands in the top center peg and pull a neutral color through them.
Step 9: Removing
Keeping the band on the hook, very carefully remove the bands with your hands.
Step 10: Almost Done
Make a single and attach it to the triple single. Look at my other instructable to learn how to make a single.
Step 11: Done
Attach a c-clip and you're done. I will be posting another instructable on how to make a triple single that goes all the way around without using a single when I buy more bands. Maybe tomorrow. Happy looming!
  • Creative Misuse Contest
  • Clocks Contest
    Clocks Contest
  • Oil Contest
    Oil Contest
5 Discussions
