Introduction: Rainbow Loom Triple Single Bracelet
Step 1: Supplies
You will need the rainbow loom starting kit, and some elastic's.
Step 2: Placing the Bands
You start by taking your first color and put it on the first left peg.
Step 3: Placing the Bands
You continue to put the bands up the board like it shows.
Step 4: Placing the Bands
As you put the bands up the board it should look like this.
Step 5: Placing the Bands
When you finish those steps you do the same thing in the next row of pegs.
Step 6: Placing the Bands
As you do it, it should look like this.
Step 7: Placing the Bands
The two rows should look like this.
Step 8: Placing the Bands
After the first two rows, you do the same thing with the last row.
Step 9: Placing the Bands
After you have placed all the bands, it should look like this.
Step 10: Placing the Bands
Next, you take in "inside" color an you make a triangle. You skip the first three pegs and start in the next three.
Step 11: Placing the Bands
You continue to do the triangle on the pegs all above the next one.
Step 12: Placing the Bands
When all the triangles are on it should look like this.
Step 13: Looping the Bands
You must flip over your board so the arrow is pointing at you.
Step 14: Looping the Bands
You take the color to the left and loop it over to the top.
Step 15: Looping the Bands
You continue to loop up the board on the left row of pegs.
Step 16: Looping the Bands
On the end of the first row, it should look like this.
Step 17: Looping the Bands
Next, you do the same thing that you did to the left row, but now you do it to the middle row. You loop up until the end.
Step 18: Looping the Bands
If you did the following steps correctly the board you have should look like this one.
Step 19: Looping the Bands
You again do the same thing that you have done to the first two rows.
Step 20: Looping the Bands
Continue the steps.
Step 21: Looping the Bands
If you did all the looping steps correctly, it should look like this.
Step 22: Finishing Up the Bracelet
In the end you take the left row of pegs and take the very en of it and put it into the middle row of the pegs.
Step 23: Finishing Up the Bracelet
To put it in the middle it should look like this.
Step 24: Fishing Up the Bracelet
You do the same thing to the right side of pegs.
Step 25: Finishing Up the Bracelet
This is one of the final steps. You take you pen and stick it though the end and put and elastic on it.
Step 26: Finishing Up the Bracelet
You pull the pen though so it turns out like this. Then you can take it off.
Step 27: Finishing Up the Bracelet
After all the steps, the bracelet should look like this.
