Rainbow Mega Pong Clock
8,352
13
7
Posted
Introduction: Rainbow Mega Pong Clock
This is my take on the clasic Pong clock with an RGB back light that changes every time the date is displayed.
A big thanks to mrnick1234567 and his https://www.instructables.com/id/Pong-Word-Clock/
I did want the light to change randomly through the day but it made a mess of the coding for the clocks.
The latest version simply selects a random combination of Red, Blue and Green and will change the back lights when the date is displayed.
If anyone has any ideas on how to adapt the code further I will try it out :-)
To get started you will need:
Arduino Uno
OR
ATMega328
16MHz Crystal
2 x 22pF Capacitors
10K Ohm resistor
A DS1307 time clock on PCB
OR
DS1307
32768MHz crystal
CR2032 Battery
Battery Holder
2 buttons
12V to 5V DC-DC converter
12V 1A PSU
Some RGB LED strips
A Frame
Plexi Glass or Perspex
Hot glue gun
Oh, and since taking the pictures it also appears that I need black silicone for the corners!
Step 1: The Brains
There is a PDF in the ZIP file of the drawing that shows it all a little better.
I have had to move a few things round to free up some of the PWM outputs so if you already have a Pong Clock set up this won't work without a few changes.
This also works with the 3mm LED displays if you fancy a Mini Rainbow Pong.
Basically assemble the controller as shown in the drawing, I used a standard UNO to slap the programe into the chip before mounting it in the holder, or you could add some risers to pins 1, 2, 3 and Gnd if you wish. then you would not have to remove the chip :)
I have also added an LED output to DO 8, this should flash at around once per second to indicate that the clock is running.
If you get errors like the time only shows 00:00 then it is probably because the voltage at your chip is less than 4.6V, you need to be as close to 5V as possible which is why I opted for the DC-DC module. I did have a 5V regulator on there but when it got hot the voltage dropped, even with its heat sink on. Probably because it ran fine with the 3mm matrix but the 5mm seem to need more power.
Step 2: Around the Back
I used the fixing holes on the matrix as a template and drilled through the plexi, then countersunk the holes and popped 4mm machine screws through and held in place with a couple of nuts, I added three washer between the nuts so the matrix PCB does not bend.
Using the all purpose Hot Glue gun I stuck the plexi inside my frame.
Then using some foam backed double sided tape I stuck the ATmega to the back of the matrix, then stuck the DC-DC converter in place next to the ULN2003A.
On this one I chose to put the ULN2003A on the frame because this was a mod to the original board and I didn't fancy doing the whole thing from scratch. All you need is the three connections to pins 5, 12 and 15 A grund wire and the 12V for the RGB strips.
Step 3: Big Brother
Mega Pong next to Regular Pong
The one on the right is using the regular 3mm LED matrix, Mega pong is on th eleft before I added the frame.
It is inherantly difficult to photo anything that lights up, especially when you are using a mobile phone to do it!
I am toying with adding more RGB lights along the top and bottom, I have another Rainbow project on the go at the moment so I will see what bits I have left ;)
Oh, and I am adding a latching button to switch off the lights, it may be soothing trying to see what colour comes next but when you are watching TV it's a different story!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Trash to Treasure
      Trash to Treasure
    7 Comments
    Pretty cool dude! =D
    Congratulations!
    Thank you :-)
    Next time I might add more LED's to the top and bottom.
    More of an even spread.
    Kind regards
    Darren
    It is beautiful.
    Best Wishes
    Thank you!
    I take it you recognise the format of the additional code then :)
    The next one is Rainbow Word Clock.
    That will be the fith clock I have built this year!
    Regards
    Darren
    How do you find the time to build so many clocks?  :-D
    Sorry, I couldn't resist!
    Best Wishes.
    Should have just said I have time on my hands :-)
    The Pong clock is so simple to make it hardly takes any time at all, that is why I like to change things and make them "unique"
    The Rainbow word clock needs a whole redesign of the electronics and the code.
    Plus it keeps me out of trouble ;-)
    Regards
    Darren
