loading
Step 12: Glue spline in place
Using more of the same epoxy, glue the spline into position on top of the magnets.  This will hold all the magnets in position forever.
Apply clamps and let the epoxy set.  I used masking tape to protect my clamp heads so that they wouldn't become epoxied in place from any squeeze out that might occur.
Once the epoxy has set, remove the clamps and sand off any glue marks.
<p>Hi there,</p><p>Love this idea and will be making one out of oak, but I don't know enough about magnets. I'm afraid I will by the wrong kind or magnets that are too weak.</p><p>Are these what you used? They say 6 lb Pull strength? http://www.rare-earth-magnets.com/magcraft-nsn0911 </p>
<p>Absolutely stunning! This came up looking for a spice rack project (guess I'll be writing my first instructable). However my only power tools are a drill and a dremel so when I have wood projects, I take advantage of the very nice people at HD to cut my pieces to size. ;)</p><p>So, do you have an etsy page???</p>
<p>If not noted yet, you can get various kinds of hardwood from pallets. I've gotten cherry, oak, walnut, pine and several others I wasn't able to identify for free from disassembling and sanding pallet pieces parts. FYI! :)</p>
Using pallet wood in a food environment is not safe. It's stupid FYI. The numerous carcinogens and poisons in lots of pallet wood makes it very dangerous to use.
Looks great! I'd love to start crafting one but don't have the tools :( Can you make another to order?
<p>Going to try my hand at this project when I move into my new place (another couple of months).</p><p>Have you put any thought into two rows of magnets, to help prevent the knives from rotating? Or is that not a concern with the strength of these? Right now I have a store-bought block (http://benchcrafted.com/Magblok.html), great quality, but the knives can rotate if I'm not careful.. plus I like the lack of visible holes on your design.</p>
Please may i know if N35 magnets will do? I'm looking into trying out this project...but confused about these numbers ...in anther instructable <br>http://www.instructables.com/id/Reclaimed-Wood-Magnetic-Knife-Rack-1/ <br>it said D55
<p>N35 is just a classification of magnet strength family. The best way to think of it is that the number after the N sets the upper bound on how strong the magnets in that classification could be. Example with made up numbers: An N35 magnet might have a pull strength from .1 to 10 lbs. An N 37 magnet might have a pull strength from .25 to 15 lbs.</p><p>If your magnet is directly in contact with your knife, then you need a pull strength at least as strong as the weight of the knife but not so strong you struggle to pull the knife off the rack. I hide the magnets behind hardwood on mine, so I use very strong magnets as the pull strength is weakened by going through the wood. <a href="http://warriorwoodwork.blogspot.com/2013/11/zebrawood-knife-strip.html" rel="nofollow">http://warriorwoodwork.blogspot.com/2013/11/zebraw...</a></p><p>I use magnets with almost a 40 lb pull strength.</p>
<p>This is a brilliant design and will be perfect for my holiday gifts this year. Unfortunately, I have to make a bunch (30) and am wondering whether I need the 40 lb pull strength. Can I go with something less to keep the cost down? </p><p>How long do you usually make the board? I was thinking 12 to 15 inches.</p>
<p>Just to cut a step I would not cut the groove till the end so I don't need to cap it</p><p>Nice project!</p>
Looks great! You mentioned the size of that magnets you used. Do you know what pull strength they were?
Very nice job! <br> <br>I love your attention to detail, such as the velcro strips to act as &quot;springs&quot; to preload the mounting. Very nice! Af\ter my own heart!!
You sure are big into rainbows. :) Good to know... <br> <br> <br>Your &quot;rainbows&quot; could probably stand a little inclusion of argentine osage orange and some pink ivory, though. <br> <br> <br>
Nice project! Where'd you buy your magnets? <br>
I usually order from http://www.rare-earth-magnets.com/ just because they have a nice website, but there are many retailers for rare earth magnets online now.
what was the pull strength of the magnets that you used? <br>
great ible and photos. looks like the perfect wedding present to me. I certainly plan to have a go at this one!
are those knives custom? The one nearest the camera in the first picture is damascus, right?
Good spot! I like to cook quite a bit, so I've taken the plunge and invested in some hand made Japanese knives sold at The Japan Woodworker in Alameda, CA. I always bought decent knives (Henckel, Wustoff etc...) in the past, but these Japanese knives are out of sight. They retain an edge better and longer than conventional knives and have a much thinner blade, yet still extremely rigid structure, which makes cutting easier and more precise because you're pushing less knife (thickness) through your material. It's like dragging a piece of fishing line through a carrot instead of a 1/4" steel cable - it's thinner, so it's easier. Hope that made sense. I could go on about the merits of Japanese knives forever...
You'd be preaching to the converted if you did ;). If only I had the money....I would buy loads from my friends on<a href="http://www.britishblades.com" rel="nofollow">http://www.britishblades.com</a>. Wonderful people they are, I'm a member myself (it's a forum)
multi colored wood, really a great project. I can't wait to make something like it. Where do you get all the different wood, or is it dymondwood?
You can get those woods at a lumber yard if you've got one close to you. The bay area luckily has some great lumber yards that stock tons of varieties. Although, good lumber yards are becoming harder and harder to find. In a pinch, you can mail order small amounts of wood online from woodworking catalogs.<br /><br />What is dymondwood?
Thanks! Dymondwood and Pakkawood is real wood, impregnated with color and resin, laminated together. I'm a wood carver and ran across carving knives made with Pakkawood by Helvie Knife. http://www.helvieknives.com/ Gorgeous handles plus they make their own steel and are exceptional blades. I did some research and found dymondwood and pakkawood for sale on the internet. http://www.rutply.com/products/dymondwood.html<br>I even found some on eBay one day. But I choose not to make my own knives, so I'm looking for storage ideas and your magnetic holder would keep me from stabbing myself both with knives and palm gouges. Yes, I've done both. Those pvc tool holders found on the internet are cheap and easy, but ugly. Wood should be involved with wood projects. :)
I made one some time ago using birdseye maple. <br> <br>Yours is fantastic!
The birdseye maple looks great - nice work! I see you've got your mounting screws going right through the front - I was going to do the same on mine before sourcing the keyhole hangers. Before I found the hangers I was thinking about the idea about getting some cool fasteners for mounting, like some big brass thumb screws, decorative wing nuts, or even, a brass wood screw with a decorative head. Just something to think about. With your birdseye, I think some stainless steel hardware would look real nice too. Anyway, great work and thanks for posting the pics.
Wow! Fantastic job! Just one concern though: I'd recommend mounting the knifes the other way (blade upwards), for safety's sake. If the magnets were to ever fail, getting hit by the handle is a lot better than being pierced by the blade.
The problem is that my magnet are really weak. Putting the knife the other way around make them slowly slide and almost fall. The wood itself is as smooth as it can get, so there's not much to grip on. <br> <br>Anyway, it's been like this for a while now and nobody ever got stabbed. The knifes sit above a spice rack that block the way if anyone want to go there.
I'll try to find picture of the back. I used circle magnet. All we did was to drill some 1/2&quot; hole one next to each other until there was very little wood left. There's like 1/16 of an inch left between the magnet and the front since my magnet where less powerfull than expected (I did use rare earth magnet). Next time I'd use thicker magnet considering the price. I paid ~$18 and the thicker one were only ~$26.<br><br>Your method of using square magnet into a slot is way easier and brilliant! Using a solid piece of wood instead of stripe would still be possible. All someone would have to do is to use a router to make the &quot;slot&quot; and stop before reaching the ends.<br><br>I'll have to make another of those knife holder one day. It was a great project to start learning wood working.
Beautiful work Noah! Nice to see a woodwork project with good photography too.
Thanks for your support James. <br /> <br />I've got a lot of projects in the hopper and they're finally getting published!
:D Next time I visit SF I'll definitely spend more time in your woodshop :D
Where did you get your magnets from? This looks great by the ways. Awesome work.
I order rare earth magnets from either MagCraft http://www.rare-earth-magnets.com/
whoops, that should read: <br /> <br />"from either MagCraft http://www.rare-earth-magnets.com/ or Applied Magnets http://www.magnet4less.com/ depending on who's cheaper.
Beautifully done!
beautiful work. And thanks for instructing about the Vix bits.
This is beautiful! My husband was just mentioning how he would like a magnetic knife strip. Thank you for such detailed instructions and great photos! Now if I can get motivated to start making it in time for Father's Day :)
So well done I'd give it 6 stars if that was possible.
About This Instructable
312,204views
710favorites
License:
Bio: I've worked for Instructables off and on since 2006 building and documenting just about everything I enjoy doing. I am now the Creative Programs ... More »
More by noahw:How to Send Art Into Outer Space Cómo soldar 意式烤面包食谱
Add instructable to:
