Rainwater Diverter Using Off-the-shelf Parts
24,469
69
Posted in HomeHomesteading
Introduction: Rainwater Diverter Using Off-the-shelf Parts
Rainwater diverters can be bought ready-made and I have one myself. However, $NZ80 is a lot more than one needs to pay. This Instructible will show you how I made my own for 2/3 the price. The idea itself came from a seminar at the local Sustainable Living Centre here in West Auckland, New Zealand, so does not originate with me - unfortunately  :[
There are lots of ways this can be done and I'm working on a couple of others already, but this method originally fired my imagination.
All these parts and the hotair gun came from the same mega-hardware store and should be readily available at your local store also (or parts that can substitute). Since building this diverter, I've tried PVC pipe moulding and could undoubtedly build this even cheaper. To find the parts I just played around with bits in the store that fitted or were close.
DISCLAIMER: heating PVC releases toxic gasses. Either use a respirator or work in a properly ventilated space. If you don't take adequate precautions with this or any other project, only you are responsible! Same applies to power tools, eg the business end of a hotair gun is HOT!
Materials:
Downpipe T-junction ("Downpipe RJ80WH junction 95' 80mm WHT" $9.84)
Large reducing bush ("Socket red bush 124-80-50" $19.47)
Small flashing cone 50mm - 32mm. ("Cone flashing 131-32" $5.38)
HDPE elbow ("Elbow female HD 20mm RXFE20" $14.84)
Interior flashing cone 80mm - 50mm (This is not on the receipt, so maybe I didn't get charged for it! About $6.00?)
Waste pipe ("Pipe waste optim 100.50.1 1.0m" $22.40) [125mm = $2.80]
PVC pipe cement [already on hand]
That's $58.33. Secondhand parts or a different construction method would greatly reduce this.
Tools:
Hotair gun
Hotglue gun
Hacksaw
Pencil
Sandpaper
Tapemeasure (or ruler)
Step 1: Interior Overflow Assembly
1 Take the 80-50mm cone flashing and insert it into the T-junction from the flangeless end up as far as finger pressure will take it (or at least so the shoulder is past the bottom of the T-junction's outlet hole).
2 Poke a tape measure down from the flanged end and hook it on the shoulder of the flashing. Take a reading where it comes out of the flanged end and subtract 2.5cm (1 inch) - this is the length of 50mm pipe you'll need. Don't be too pernickety with this: it is more important that whatever length you choose, the top of the overflow is level with the maximum height of the water in your tank. This is determined when you fit the diverter to the downpipe on your house.
3 After sanding off the cut end of the pipe, glue the pipe into the flashing so it is flush (level) with the bush's shoulder. Again, not critical but make sure that the top of the overflow pipe is shortened to be about 2.5cm below the T-junction flange.
4 You could glue the overflow assembly into the T-junction, but as it is a very snug fit I've left mine unglued for now until I see how the diverter handles detritus.
Step 2: Outlet Assembly
1 Use the hotair gun to soften the outlet flange evenly around its circumference until it feels like rubber. Insert the 80-50mm bush at an angle and slowly push it in as you rotate it. If the flange is properly heated, the bush should slide in all the way to the end. You can either wait for the PVC to cool down, or cool it with water (a running tap in my case). As the flange cools, it shrinks slightly, so the bush should be a tight fit.
2 Soften the large end of the small flashing cone until it is quite soft then carefully force it into the 50mm hole in the large bush. This is a tricky step so take it slowly. You'll end up with a shape that tapers rapidly from the cone's shoulder to a 50mm outside diameter ("OD") tube. Don't glue this in just yet.
3 Soften the small end of the cone the same way as for the T-junction flange, and insert the elbow using the same technique as for inserting the bush.
4 Glue the cone into the bush, and the elbow into the cone (you can't use PVC cement, so this is where the hotglue gun comes in). You could glue the bush into the T-junction, but for me it is a very tight fit and leaving it loose means I can pull out the outlet assembly should I need to clean out the diverter without taking it off the downpipe.
Step 3: Fit Diverter to Downpipe
This Instructible is about building the diverter itself, so I'm not going into specifics here about fitting it (that's another 'ible on its own!), save to say that a section must be cut out of the downpipe such that the top of the overflow pipe is the same height as the tank's full level. The bottom of the diverter fits into either a bought connector, or you can make a flange by softening the top of the lower downpipe and forcing the diverter into it (please note that the Gutter Witch has a lip inside its lower flange which stops water leaking out around the lower downpipe .... hmmm, if the overflow pipe extended sufficiently THROUGH the interior flashing cone, then the diverter could have a lower flange rather than the downpipe! Must try that and edit this Instrucible...).
I'll take some pics and create another Instructible showing the installation process .
Oh BTW, if you like deforming PVC go check out Thinkenstein's stuff! And trevormates' "PVC 101".
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    3 Comments
    Good idea. A tip though, anything not glued with water inside for a length of time will leak like a sieve. I made a manifold between my two tanks so they could both overflow the excess water into the same overflow pipe. I left that unglued to clear debris from the screen I inserted to keep out mosquitos, but because they held just one centimetre of water, it constantly dripped after rain fell.
    Just wanted to say - nice instructable. We must shop at the same mega hardware store...
    I copied your instructable but once I got home with the parts found that I had a 60mm downpipe... so I took them all back and swapped :)
    I also managed to reduce the parts list - the inside pipe was swapped for a bit of plastic ice cream tub lid rolled up and glued in. The end reduction setup was swapped for an end cap with the correct size hole drilled in.
    One day I will get out and photo the mass of duct tape to compare ;)
    Bunnings Mt Roskill in this case. Good idea for the inside pipe: out-of-the-box thinking like that would drop the cost dramatically! I've got some ideas for reducing the cost, still using OTShelf stuff, and will post them when/if I go ahead with them (actually, rereading your post I think you had exactly the same idea about the end-cap! I was going to leave mine press-fitted, rather than glued, on so I could remove it to clear out leaves etc). I'm glad this inspired you, and I look forward to seeing your diverter.
