3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rainwater drip irrigation system
Here's a simple drip irrigation system that uses gravity to put rain water from a rain barrel exactly where it's needed in the vegetable garden. This dripper is designed for a square foot garden system, but can be used in any garden situation.
Drip irrigation is very efficient. Water is put exactly where it's needed-at the root system of the plants. No water is wasted due to runoff or evaporation.
This is my entry for the Get in the Garden contest. I hope you like it!
Step 1Dripper Materials
Dripper Materials
This project is constructed out of 1/2" PVC. Here's what you'll need:
4 4" long pieces of 1/2" PVC
2 36" long pieces of 1/2" PVC
2 90 degree elbows for 1/2" PVC
1 four way connector for 1/2" PVC (a tee connector could be used here)
1 female hose connector for 1/2" PVC
1 male connector for 1/2" PVC (if a tee connector is used, this isn't needed)
2 end caps for 1/2" PVC
1 drill
1 1/16" drill bit
1 hacksaw
PVC primer
PVC glue
tape measure
Sharpie
16 comments
May 9, 2012. 1:59 PMpcooper2 says:
As the author of the article, can't you simply correct it?
May 3, 2012. 10:38 AMkeelytm says:
Thanks for this instructable! It actually seems doable with my limited skills. I am not known for my green thumb, but this year I really wanted to start a garden and grow my own veggies. Since I live in the desert, it can get really hot and dry so I know that a good irrigation system is important. I like that this one will prevent runoff and evaporation.
Jan 13, 2012. 6:06 AMmacmcb says:
I know it's been a while since this post, but... Does more water drip from the holes closest to the rain barrel? (If so, how much more?)
I'd like to build this myself and wonder if anyone has noticed this issue. Thanks for the great instructable.
Jun 11, 2010. 4:39 PMrhaubejoi says:
Very cool instructable. Great idea using things we usually keep around the house (having a well instead of city water and living in a VERY rural area teaches you that its cheaper to have some extra pvc and connectors on-hand than to drive 30 miles for a 15 cent part!) Thanks for a great idea and a well written/documented project!
Jul 18, 2009. 4:07 PMantpix says:
Great concept. An alternative idea, would to replace the piping with offcuts of hose pipes to allow more movement around plants.
Jun 15, 2009. 10:57 AMWal- Tor says:
Isn't drip irrigation supposed to be controlled by a computer that knows how much water is needed?
Jun 15, 2009. 1:33 AMawang8 says:
Umm... I don't know if this works for anyone else but my water tank (no pump, just pressure-powered) tends to pump out so much water that it's more of a stream than drops.
Jun 13, 2009. 2:21 PMJason_G says:
A simple & expandable drip system- very nice. Looks so simple, I bet even I could do it. How many do you have chained together in your garden?
Jun 13, 2009. 2:15 PMkudoskun says:
Does the hole drilled side go up or down in the garden? Im guessing down, so water doesnt sit in the tubes and stagnate...
Jun 13, 2009. 2:14 PMkudoskun says:
Simple and straight-forward. I like +1
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:Tree Frog
