Picture of Rainwater harvesting: Rain Barrel DIY
Rain water collection. Nature's most fundamentally important resource for human habitation -- the earth purifies it from all sorts of sources through the evaporation process, transports it all around the globe, then drops it from the heavens for us to drink, water our crops, bathe and swim, among myriad other uses. Modern humans have found lots of ways to squander precious fresh water, but this easy, inexpensive solution captures an potentially lost resource for effective reuse. How much more green could an Instructable be?
Rain barrels capture rainwater otherwise lost through the downspout to use for watering your garden between rains. But rainwater harvesting has lots of benefits beyond simply watering your garden. It's also good Green Tech. It's a low-cost solution for a number of potential issues:
  • It reduces stormwater runoff created by the roof of your house
  • It can reduce property drainage problems
  • It contributes to a LEED Green Building rating
A rain barrel collection system is simple and easy to maintain, Rainwater is better for gardens and landscape plants than municipal water because it doesn't contain chlorine, it's relatively clean and it's absolutely free. It is also a system that can be expanded easily to create additional rainwater storage, and it can be dismantled and relocated if necessary.
This instructable documents how to construct a simple rain barrel used to collect rainwater runoff from a downspout. It uses readily available parts found at your local hardware or plumbing supply store, and it uses basic tools found in many tool kits. For those tools you don't have, they're easy to source and inexpensive.
IamSparticus4 months ago
I'm building my rain barrel with that same style barrel and I'm concerned about it being unstable due to the tapered base. Have you had any problems with that?
Thanks for the unstructable. I will copy many of your ideas.
GeeDeeKay (author)  IamSparticus4 months ago
Glad you like it, I have 2 I've made and have had no problems at all. Remember, these barrels are designed to hold things like pickles and olives, so they hold liquids by design. The base is smaller than the overall diameter, but plenty stable. Keep it on a stable, level surface that can support the weight of 55 gallons of water and you should have no problems.
I have made one modification since this was posted. I have inverted the strainer on the lid, so it points up instead of down, This has eliminated clogging of the strainer almost completely.
Let me know how your barrel turns out!
agoaga2 years ago
nice.
can we used a 19 ltr tube also for the same method?
jerhpk2 years ago
Great 'ible. Also, remember to check your local code on rain barrels. Previous city I lived in had a law that stated the rain barrel must be disconnected during winter months, and drained completely. Plus, rain barrels were not allowed to be visible from the street. (Since I lived on a corner, this was difficult.) The exception was detached garages - there was no ordinance covering these units, so they could be left in place year round.
My question on the previous model you referenced with the flexible hose: did the water ever run fast enough to dribble over the lip of the top of the barrel?  With the concern locally over West Nile, I'm wondering if the water will pool and puddle (even splashover) or if it all drains in.
GeeDeeKay (author)  jerhpk2 years ago
Thanks for the comment. I haven't heard of local ordinances regarding rain barrels, so that's interesting information. I did mention removing rain barrels during winter months, to keep them from getting damaged by freezing weather.
What did you mean about detached garages and leaving them in place year round, I'm not sure what the "they" referred to in your statement. Is sounds like the garages could be left in place, which makes sense to me... ;^)
I have never had a problem with water overtopping the barrel, even during really heavy storms. It is important to clean the screen from time to time to keep it clear of debris, but with a 3" opening there is plenty of room for the water to enter. Interesting point about mosquitoes; I do find that the top pools a little bit, so I drill 2-3 small weep holes through the top on the low side, to allow those pools to drain.
The screen on top keeps adult mosquitoes out of the barrel and prevent egg laying. It also keep adults in that happen to wash in as larvae and mature inside the barrel. The concern is exposed standing water for mosquitoes to reproduce, so no exposed pools means no habitat for larvae to mature.
Browncoat2 years ago
You could prob enter this in the Water Challenge.
http://www.instructables.com/id/Summer-Water-Challenge/
