Introduction: Raised Bed Wicking Garden
Picture of Raised Bed Wicking Garden
I wanted a raised bed planter, but the best location in my yard is not close to a spigot for watering. I live in a hot climate and I wanted to find a way to avoid dragging out a long length of garden hose 3-4 times a week to water my garden. I finally settled on building "wicking" raised garden bed. While I still need to pull out the hose once in a while, the number of times is much less. This bed waters from the bottom up, which has many benefits but here are a few key:
- Less evaporation during watering
- Plants are encouraged to grow deeper roots
- Lower water usage because garden draws up water only when needed
This guide will show you the key steps to building your own backyard raised bed garden which needs less frequent watering and encourages deep-rooted healthy plants. The key to this garden is the "wicking" water system built into the bed.
Materials needed for 4'x6' garden.
- Wood for raised bed walls (adjust to fit your garden dimensions)
- 2 2x6x10'
- 2 2x10x10'
- 2 1x4x8' for corners (optional - mostly decorative)
- Galvanixed screws
- 1" PVC for fill pipe and holders for cover supports
- Weed barrier
- Poly liner
- 4" corrugated drainage pipe
- 2 end caps for 4" drain pipe
- drainage rock
- organic garden soil
I purchased everything at my local "big box" hardware store
Step 1: Build Raised Box Container
Picture of Build Raised Box Container
Begin by constructing your raised container. There are many options for this container, I chose a simple wooden box which is approximately 4' x 6' in size. You can choose to let the wood age naturally, but I decided to put a grey stain on the outside and along the top of the inside. There are many techniques and sites which will show you how to construct the box, and you can probably figure out my approach just from this picture.
Once you have your box located and leveled, dig out some of the soil to form a depression which is below the level of the box approximately 4 inches. (The deeper you dig, the more water it will hold.)
Note: Do not use pressure treated lumber if you will be growing vegetables.
Step 2: Build the Water Containment System.
Picture of Build the Water Containment System.
Next line the depression with a poly liner. I purchased mine from the local big-box hardware store in the paint department. I wrapped the plastic up and attached it to the lower edge of the wooden box with galvanized roofing nails. In the lowest corner, I did not fully attach the plastic at the top, so that water could run over when full.
Once your liner is installed, prepare a section of corrugated drainage pipe. This pipe is 4 inches in diameter and has small holes throughout the pipe to all water to escape. Place a cap on each end of the pipe. In one end, drill a hole and insert a PVC pipe which will be used to fill with water. No need to bother gluing everything together; the purpose is to let the water seep into the rocks anyway.
Next lay the prepared pipe into the depression. I recommend you size the pipe to run the full length of your bed, but it is not critical to loop the pipe as I have done here. The pipe simply speeds up distribution of the water throughout.
Next fill the depression with rocks. Ideally you will fill to the top of the corrugated pipe
Step 3: Cover the Pipe and Rocks
Picture of Cover the Pipe and Rocks
Next, cover the pipe and rocks with a weed block material which still lets water pass through. This barrier will allow water to pass in both directions, but will keep the lower reservoir from filling in with soil. The pipe and the gaps between the rocks is where you garden will store water for when it is needed by your plants. I have weighted mine down with a few rocks to ensure it stays in place for the following steps.
Step 4: Add Extras to Your Bed
Picture of Add Extras to Your Bed
Before you add garden soil, it's a good time to add any extras you may want in your garden. I have added 6 small vertical pieces of 1" pipe (3 on each side). I can insert the end of 1/2" pvc pipe into one side, then bend the pipe over the bed and insert into a pipe on the other side. These pipes will then support netting to keep out garden critters; or I can use the supports for row covers to keep out frost on chilly nights.
(You may also notice that I filled the gaps between the slats in my box ... the wood was warped and the gaps were a little larger than I wanted.)
Step 5: Partially Fill and Test
Picture of Partially Fill and Test
I added about half of the organic soil to the bed and then stopped to test the system. I have added a small tube to the lowest corner where I left the corner of the liner lowered. I also created a small depression which runs under the wooden box. I then filled the water reservoir using the fill pipe until I saw water spilling through the tube and the depression in the soil. (The tube is probably not necessary, but I wanted to be sure the water would escape when the reservoir filled.
I also ensure the system was working by making a small depression in the soil down to the barrier. As it overflowed, I could see water form at the bottom of the depression. This let me know that water was passing through the barrier and into the soil. When the garden soil becomes too dry, the soil will "wick" up water through the barrier. This moisture will be pulled up through the soil so that it can be used by the plant roots.
NOTE: Making sure the water can overflow the reservoir is important. You don't want the water filling up your entire raised bed and drowning your plants.
Step 6: Fill the Bed With Soil
Picture of Fill the Bed With Soil
Now that you are certain the system is working, you can finish filling your raised bed.
(That's my beagle, "Snoopy", photo bombing my Instructable.)
Step 7: Start Planting!
Picture of Start Planting!
Start adding plants! You may still need to water newly planted seeds until they germinate, but once established you should only need to water occasionally. You can check the water level using your fill pipe by using a dowel rod as a "dipstick".
Happy planting!
ladaca (author)2017-02-25
shamanic1, Your date of 1978 is a bit early.
On December 31, 2003, the U.S. wood treatment industry stopped treating residential lumber with arsenic and chromium (chromated copper arsenate, or CCA). This was a voluntary agreement with the United States Environmental Protection Agency. CCA was replaced by copper-based pesticides, with exceptions for certain industrial uses.[2] CCA may still be used for outdoor products like utility trailer beds and non-residential construction like piers, docks, and agricultural buildings.
The U.S. began mandating the use of non-arsenic containing wood preservatives for virtually all residential use timber in 2004.
shamanic1 (author)2016-05-23
Thank you for an excellent design! My 2 cents re pressure-treated wood. The toxic metals are no longer used - haven't been since 1978. I was thinking of not making mention of this fact, because those of us who scrounge pressure treated, here in Pudddletown (Oregon), are more than happy to enjoy our little secret! ;-)
cpikturna (author)2015-09-07
Hello comment section, I have an emergency. I am using this design for my eagle project which is in 2 weeks but I didn't realize the instructions do not tell you how to build the actual box. If someone could please tell me how to build the box above with the same wood given in the instructions, that would be amazing.
ataylor69 (author)2015-05-25
What type of soil do you use? Is it just topsoil or more of a potting soil mix?
pidroelpirata (author)2015-04-13
What was your overall cost?
Grunambulax (author)2013-11-24
Nice design. Two suggestions. First, you want to cap the tube going into the container when not in use to avoid the odd rodent exploration possibility. I did this with my earthtainer clone. Second, I used a cork with piece of light plastic rod as a floating dipstick. The rod went thru a small hole drilled into the cap. I had one mark for full and another for empty and that way I could tell the level of water by looking at the height of the dipstick
Clever idea. Do you have a picture of this?
pritshah (author)2013-11-21
why is it a bad idea to use pressure treated wood for the bed?
vonPongrac (author)pritshah2013-11-22
Because of the chemicals in it. They can get into soil and into plants.
kinderdm (author)vonPongrac2013-11-22
I wanted to ask specifics on this as the info I had found said the only chemical of concern with vegetables was arsenic which hasn't been in pressure treated wood since 2004. Are there other chemicals the plants will take up that my info maybe didn't cover? If so what am looking for? I ask because I am poor and my deconstructed deck is slated to make some nice raised beds for me before next season. Thanks.
kiwibum (author)kinderdm2014-05-23
Using pressure treated wood is up to you, as you say, they haven't used lethal (that we know of) chemicals for treatment for some time. A friend worked at a saw mill, one day they were discussing this issue and calculated how much wood you would have to consume to get near problem levels. The amount of treated wood was in the measure of many cubic yards.
Treated timber isn't an issue if you are doing a wicking bed anyway, because you often use a plastic liner inside the bed which will keep soil away from touching anything leaching out of the wood. Check out some of the other wicking beds here on instructables to see what I mean regarding using a liner. Hope that helps. If it was me, I would be making good use of that decking timber and building a lined type bed.
Grunambulax (author)kinderdm2013-11-24
I have to agree about not using pressure treated wood. Perhaps Arsenic is the most toxic and worrisome, but if you are using this to grow food you will eat, then you are taking the risk that in 10 years research will demonstrate a link between illness and whatever is presently being used to treat wood. You can find untreated wood inexpensively at may places. Construction sites will often have dumpsters full of culls. My local big box store has nearly free pieces that are warped or odd-sized. We also have a place called Construction Junction that has recycled lumber. Finally Craig's List often lists free wood that you can take for the hauling.
About This Instructable
110,112views
631favorites
License:
More by FL_CDH:Raised Bed Wicking Garden
Add instructable to:
