3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Raising Cockroaches (Intentionally)
Step 2Make the Habitat
Make the Habitat
get a container with tall walls and which is farely wide (at least 7 inches.
Smear a thin layer of petrolium jelly (vaseline) all around the upper edge of the walls. Make this smear band about two or three inches thick. 90% cockroaches can't climb through vaseline, but check on the internet if you use a species other than periplaneta americana (what I have). In some species the nymphs can climb through the vaseline but older ones cannot.
Get some old newspaper, tear it into pieces about the length and width of your container. Crumple them up a couple times to give them texture. Lay them down in your container, one on top of the other. Make about five layers.
Get a large cap from some container lying aorund, it should be about two inches in diamter. Cut a square piece off a sponge so that the corners of the piece just barely touch the sides of the cap you have. Put this into your container, it will be the water dish. Add water until it reaches the rim of the cap you're using (this means the sponge is saturated and you'll have a reservoir of water to keep it that way).
NOTE:
Make sure there is not a big gap between the sponge and the cap edge, otherwise the roaches will have a hard time stepping onto the sponge to drink.
If you want to put on a top to the container make sure it's porous, otherwise it will get way to humid in there and mold will grow like crazy.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
81
Author:leevonk
www.leevonk.com
