iImage Information
My car is too low for steel auto ramps. The cowling under the bumper touches the ramps before the wheels do. I made my own ramps from 2 x 8 lumber.
Step 1Determine the dimensions
iImage Information
I needed to know the angle of the ramps' incline and the length of the incline. I used a block and a piece of 1 x 6 lumber. The 1 x 6 clears the cowling under the front bumper with a little to spare. My old ramps were 8 1/4 inches high where the wheel rested. I would like to duplicate that on these ramps. The base of the incline needs to be about 30 inches long (yellow tape measure).
By the way, thanks for sharing
To reduce weight on my version, which would appear to be the image of yours, I drilled holes in the center pieces. The size of the holes significantly reduced weight without compromising strength.
To address the height issue for the Honda, I merely add another board in front, which has a bevel cut to match the ramp and one which rests on the ramp bevel cut.
It doesn't take much to tie the "small ramp" to the big one. You can drill holes in the large ramp for pins (installed on the little ramp) to go through that can be locked in place by slipping a nail through holes drilled in the pins. You can use Velcro or some other imaginative means, like eye hooks on the sides and small bungie cords, and so forth.
Ive made a couple sets of ramps over the years, mainly because Im 2 cheap to pay for the metal ones and building sites have plenty of useful material. While I like your light idea I would still like a block across the front.
This is a well thought out and executed 'ible", use them in safety
. Probably be a good idea to install a stop at the end of the ramp. It won't prevent from driving off the end if you want to, but should provide enough resistance to let you know you are at the end (if you are paying attention). Or does the switch stick up far enough to handle that job?
. I think you need to install some EL wire under your car. :)
Thanks for the comment.
. Since you seem to be open to suggestions, I'd mount a "MicroswitchTM" or some other type of limit switch on the side of the ramp and use a welding rod or equiv to sense the tire. Should be able to mount that to the side of the ramp with screws and avoid any welding (and it doesn't have to be so rugged).
One idea I had, but have not tried, involves a light framework that hooks over the open crack between the fender and the engine hood. It would also attach to the fender with old speaker magnets. It would be like a lateral pyramid with an adjustable mirror at the point on the pyramid. The idea would be to view the tire position in the mirror while driving up the ramps. The mirror would have to be "big enough."
. The mirror idea sounds like it would work very well, but it also sounds like something where the alignment would have to be tweaked every time you used it. Not easy for one person to do.
. IMNSHO, unless you plan on selling this to the general public, the switch/light is enough, especially if you go with a "fail-safe" arrangement as per previous comment. YMMV
In regard to the general public, H L Mencken said, "No one ever went broke underestimating the intelligence of the American public."
