Introduction: Ras3Der. One-Click Photo to 3D Model.
Ras3Der, my free tool of 3d Model Viewer, Converter, 2D image to 3D model.... etc.
Convert image to 3D Model in just 3 Steps.
Step1 : Load image file ( bmp, jpg, gif...)
Step2 : Select Converting Mode.
Step3 : Save 3d Model ( STL, 3ds, obj...).
Video:
Quick Start:
  https://youtu.be/gywQh5ypY3E
Kinds of 3D Model effect:
Image-Processing, Cropping, Set Model Size, thickness.....:
All Videols:
Download :
http://www.rasvector.url.tw/Ras3Der/ReleaseRas3De...
More free tools:
http://www.rasvector.url.tw/hot_91270.html ..
Step 1: Load Image File.
Picture of Load Image File.
First, let's load an image file from [File] / [Import] / [Raster Image] menu item.
You can switch language as you want under the drop-down menu items of language.
Step 2: 3 Image-processing Modes to Get Different Kind of 3D Model Conversion.
Picture of 3 Image-processing Modes to Get Different Kind of 3D Model Conversion.
There are 3 modes for image-processing.
Mono : Will create a 3d model with only 2-level of height.
Gray : Will create a 3D model with smooth height.
Color : Will create a 3D Model with segmented height.
Also you can invert the image, cropping image as you want.
There are "Restore Original Image" that let you to undo the crop.
And you can adjust the smoothness by drag the scrollbar or enter the value in edit box.
Step 3: Start Converting.
Picture of Start Converting.
Once finish Image-Processing. Press "OK" to start converting Image to 3D Model.
1. Enter the size ( CM ) of model width.
2. Enter the value ( CM ) of model thickness.
Step 4: Get a 3D Model From Image File.
Picture of Get a 3D Model From Image File.
Now we get a textured 3D model converted from an image file.
You can hide the texture to see the plain model.
Finally, save the model as a STL 3D file, that you can use it to print the model directly from a 3D printer.
Step 5: Also It Is a 3D Model Viewer and Converter.
Picture of Also It Is a 3D Model Viewer and Converter.
You can also load kinds of 3d Model file by this tool.
And export kinds of file format as well.
There are also many functions that you can
Show/hide lights, change light color,
Mouse Left/Middle/Right key to Rotate/Zoom/Move View.
Display model in point / frame / solid mode.
For those not mentioned, please try them by yourself.
Step 6: Model Result of 3 Modes Image-processing.
Picture of Model Result of 3 Modes Image-processing.
Daniel Lu (author)2017-05-15
Post your photo here. Let me know it helps.
DukeMagus (author)2017-05-11
It's a pretty powerful tool, but needs more documentation
could you make an english version of the program and your site?
Daniel Lu (author)DukeMagus2017-05-11
Hi, DukeMagus,
It's a pretty easy-to-use tool. There are many demo videos in my youtube channel. Just watch the videos, and you should easily know how to use it. https://goo.gl/2A0xgO
Since there are lots of free resources, many kinds of Arduino projects, Engineering Tool, 2D, 3D in my website. It will take time to make an English version. I do need help to do those things.
For now, use Google Translator, try to explore those resources. You should find more powerful free tools. Or send me an email, telling me what tool you need.
There are also some pieces of English document, tutorial videos. Try to explore it by yourself.
Eg. Videos in my youtube.
RvSciViewer,
a free tool for MicroScope, Spectrum, Measure...
https://goo.gl/tke1rt
RvJustviewer,
a clean, powerful viewer.
https://goo.gl/Z3nJkO
RasTiler,
a montage tool.
https://goo.gl/Lb0v1G
Download here:
Feel free to email me at dan59314@gmail.com
Daniel
About This Instructable
2,307views
26favorites
License:
Bio: A programer, maker, painter.        FB : https://www.facebook.com/dan59314       Linkedin: https://goo.gl/avBXpR
More by Daniel Lu:Easy Arduino Library  DanLibTake a Clean Picture Without Annoying People.Turned Your Old Phone Into a Motion Alarm Guard.
Add instructable to:
