Introduction: Rasberry Pi Laser Cut Cardbboard Case
I recently got an RPI 3 and like everyone else, I was excited to start doing stuff with it. But of course I need a case to keep it place and avoid it from falling off the table. I was out of plastic sheets which I would normally use for this sort of stuff but I was a bit impatient and wanted to build something instantly.
So Let's build it already! :)
Step 1: Drawings & Materials
The case I wanted to build is something that would be small enough to carry around and would have enough vents / openings to keep the RPI 3 cool while in operation.
I measured the Pi and drew my design in cad. NanoCad is a free cad software you can use to view and modify the file.
Since I was out of plastics, I came across some card boards that were fairly stiff. I glued about 3 sheets together using instant glue / adhesive (Loctite 401) to get about 2mm of thickness.
You can arrange the drawings so it will fit your laser cutter and material.
I was not planning on making an instructable about this, so the pictures are mostly after I was able to cut and assemble the pieces together.
The support legs are assembled as illustrated on one of the pictures.
Step 2: Paint It (optional)
Just 2 passes of spray paint does a great job in hiding the burn marks on the cardboard. :) Let it dry and pop in the RPI.
Thanks for viewing.
