Raspberry Cheesecake Cupcakes by ekosmas
Contest WinnerFeatured
If you enjoy cheesecake, then you will love these cupcakes. They consist of cheesecake with a graham cracker crust, a layer of homemade raspberry jelly, and are topped with cream cheese whipped cream. Can you say yum?
Ingredients:
Cheesecake
(3) 8 Ounce Packages Cream Cheese
4 Eggs
1 Cup Sugar
1/3 Cup Heavy Whipping Cream
1 Tablespoon and 1 Teaspoon Flour
1 Teaspoon Lemon Juice
1 Teaspoon Vanilla Extract
Fresh Raspberries for Garnish
Cream Cheese Whipped Cream
2 and 2/3 Cups Heavy Whipping Cream, liquid not already whipped
3 Tablespoons Cream Cheese, softened
Raspberry Jelly
1 and 1/3 Cups Raspberries, fresh or frozen
3/4 Cup Sugar
1/4 Cup Water
Graham Cracker Crust
1 Cup Graham Cracker Crumbs
1/3 Cup Butter, melted
2 Tablespoons Granulated Sugar
1 Teaspoon Brown Sugar
1/2 Teaspoon Cinnamon
Step 1: Make the Raspberry Jelly
Bring the raspberries, sugar and water to a boil in a small saucepan over medium heat. Mix well, breaking apart the raspberries with the end of your spoon. Allow to boil for 7 minutes, then remove from heat and allow to cool for 30 minutes. Then put it in the refrigerator to chill.
Step 2: Make the Graham Cracker Crust
In a small bowl, mix together the granulated sugar, brown sugar cinnamon, and graham cracker crumbs. Add the butter, and mix well. It should get kind of clumpy now, and should stick together if you press it between your fingers. Set it aside.
Step 3: Make the Cheesecake
In a large bowl, mix together the flour, sugar, and cream cheese until well blended. Add the heavy whipping cream and mix until combined. Add the eggs, one at a time, blending well after each addition. Stir in the lemon juice and vanilla extract.
Step 4: Assemble the Cupcakes
Preheat the oven to 325 degrees Fahrenheit. Get out your cupcake pan and put in cupcake liners. Place 1 tablespoon of the graham cracker mixture at the bottom of each cup, pressing it into the bottom of the cup gently with the backs of your curled fingers. Then, place 1 teaspoon of the raspberry jelly in the center of each of the graham cracker crusts. Next, fill each cup 3/4 full with the cheesecake mixture. Place the pan in the oven and bake for 8 to 10 minutes, then turn the heat down to 275 degrees Fahrenheit and continue to bake for another 12 to 16 minutes, or until the tops of the cheesecakes are golden. They will crack at the top, and that is okay, because we will be covering the cracks with whipped cream.
Step 5: Make the Whipped Cream
While the cupcakes are baking, make the cheese whipped cream. Put the heavy whipping cream and cream cheese in a medium-sized bowl. Using an electric mixer, beat the mixture on high for about 2 minutes, or until a dense and thick whipped cream forms. This will be much thicker than store bought whipping cream, and it will pipe out of the frosting bag quite nicely! Cover and refrigerate.
Step 6: Chill the Cupcakes
Once the cupcakes are done, remove them from the oven and allow them to cool to room temperature. Then, place them in the refrigerator for 30 minutes to chill. Now they are ready to be frosted.
Step 7: Frost the Cupcakes
Fit a frosting bag with a size 13 closed star frosting tip. Now fill the bag two-thirds full of the whipped cream and roll down the empty top of the bag until the whipped cream is nice and compacted inside, as air bubbles will cause the frosting to sputter out messily rather than in nice, clean strokes. Grab a cupcake and start icing it around the outside edge, continuing around the edge until you are about to meet the point where you started frosting. Curl the frosting into the center of the cupcake, and you are done! It is basically like making a single, large spiral.
Repeat this process with all of the cupcakes. Garnish the tops with a single raspberry. Serve immediately and refrigerate any leftovers.
garnishrecipes says: Jul 17, 2012. 5:26 PM
Very beautiful photography!
charlotte555 says: Feb 25, 2012. 11:03 AM
How much flour do you add to the cheese cake?
jallen-gordon says: Apr 13, 2012. 11:02 PM
I really don't think flour goes in the cheese cake mix.
laroxy323 says: Apr 9, 2012. 8:58 PM
This hands down is the best recipe for homemade cheesecake!
I have made this countless times for various occasions and is always a hit, I can surely say I have found my one go-to recipe and will not be using another. The jelly is perfect you can make either raspberry, strawberry or mixed berries (blueberry is a bit bland) the only remark I can make is the crust portion makes about 16 "cupcakes", I always have a remainder cheesecake mix to make an additional 12 cupcakes or one round sized 12' pan.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
