Raspberry Pi - ADXL345 3-Axis Accelerometer Python Tutorial
2,910
Posted
Introduction: Raspberry Pi - ADXL345 3-Axis Accelerometer Python Tutorial
The ADXL345 is a small, thin, ultralow power, 3-axis accelerometer with high resolution (13-bit) measurement at up to ±16 g. Digital output data is formatted as 16-bit twos complement and is accessible through I2 C digital interface. Itmeasures the static acceleration of gravity in tilt-sensing applications, as well as dynamic acceleration resulting from motion or shock. Its high resolution (3.9 mg/LSB) enables measurement of inclination changes less than 1.0°. Here is it demonstration with raspberry pi using python code.
Step 1: What You Need..!!
1. Raspberry Pi
2. ADXL345
LINK : https://www.controleverything.com/content/Accelorometer?sku=ADXL345_I2CS
3. I²C Cable
LINK : https://www.controleverything.com/content/I2C-Cables?sku=I2CAFF3
4. I²C Shield for Raspberry Pi
LINK : https://www.controleverything.com/content/I2C-Master?sku=TOUTPI2
5. Ethernet Cable
Step 2: Connection:
Take an I2C shield for raspberry pi and gently push it over the gpio pins of raspberry pi.
Then connect the one end of I2C cable to ADXL345 sensor and the other end to the I2C shield.
Also connect the Ethernet cable to the pi or you can use a WiFi module.
Connections are shown in the picture above.
Step 3: Code:
The python code for ADXL345 can be downloaded from our github repository- ControlEverythingCommunity
Here is the link for the same :
https://github.com/ControlEverythingCommunity/ADXL...
The datasheet of ADXL345 can be found here:
https://s3.amazonaws.com/controleverything.media/c...
We have used SMBus library for python code, the steps to install SMBus on raspberry pi is described here:
https://pypi.python.org/pypi/smbus-cffi/0.5.1
You can also copy the code from here, it is given as follows:
# Distributed with a free-will license.
# Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
# ADXL345
# This code is designed to work with the ADXL345_I2CS I2C Mini Module available from ControlEverything.com.
# https://www.controleverything.com/content/Accelor...
import smbus
import time
# Get I2C bus
bus = smbus.SMBus(1)
# ADXL345 address, 0x53(83)
# Select bandwidth rate register, 0x2C(44)# 0x0A(10) Normal mode, Output data rate = 100 Hz
bus.write_byte_data(0x53, 0x2C, 0x0A)
# Select power control register, 0x2D(45)
# 0x08(08) Auto Sleep disable
bus.write_byte_data(0x53, 0x2D, 0x08)
# Select data format register, 0x31(49)
# 0x08(08) Self test disabled, 4-wire interface
# Full resolution, Range = +/-2g
bus.write_byte_data(0x53, 0x31, 0x08)
time.sleep(0.5)
# Read data back from 0x32(50), 2 bytes
# X-Axis LSB, X-Axis MSB
data0 = bus.read_byte_data(0x53, 0x32)
data1 = bus.read_byte_data(0x53, 0x33)
# Convert the data to 10-bits
xAccl = ((data1 & 0x03) * 256) + data0
if xAccl > 511 :
xAccl -= 1024
# Read data back from 0x34(52), 2 bytes
# Y-Axis LSB, Y-Axis MSB
data0 = bus.read_byte_data(0x53, 0x34)
data1 = bus.read_byte_data(0x53, 0x35)
yAccl = ((data1 & 0x03) * 256) + data0
if yAccl > 511 :
yAccl -= 1024
# Read data back from 0x36(54), 2 bytes
# Z-Axis LSB, Z-Axis MSB
data0 = bus.read_byte_data(0x53, 0x36)
data1 = bus.read_byte_data(0x53, 0x37)
zAccl = ((data1 & 0x03) * 256) + data0
if zAccl > 511 :
zAccl -= 1024
# Output data to screen
print "Acceleration in X-Axis : %d" %xAccl
print "Acceleration in Y-Axis : %d" %yAccl
print "Acceleration in Z-Axis : %d" %zAccl
Step 4: Applications:
ADXL345 is a small, thin, ultralow power, 3-axis accelerometer which can be employed in Handsets, Medical instrumentation etc. Its application also includes Gaming and pointing devices, Industrial instrumentation, Personal navigation devices and Hard disk drive (HDD) protection.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    2 Questions
    i got this error can anyone help me out
    Traceback (most recent call last):
    File "/home/pi/m4.py", line 10, in
    File "/home/pi/.local/lib/python2.7/site-packages/smbus/util.py", line 59, in validator
    return fn(*args, **kwdefaults)
    File "/home/pi/.local/lib/python2.7/site-packages/smbus/smbus.py", line 145, in write_byte_data
    raise IOError(ffi.errno)
    IOError: 121
    hey,i got this error,can anyone help me out
    IOError: 121
