Raspberry Pi Cooling.
Published
Introduction: Raspberry Pi Cooling.
This is my first Instructables.
Step 1: Things You Need.
Raspberry pi
Raspberry pi overclock kit (fan, heat sink.)
Case (optional)
A computer
Printer
Google sketch up
Pepakura designer
X-Acto knife
Glue
Step 2: Google Sketch Up.
Make the design using Google sketch up and export it out as a .dae file.
Step 3: Pepakura.
Open pepakura designer 3 and unfold it. Make for sure your sizes are right. Then print it.
Step 4: Cutting.
After you printed it you are going to need to cut it out with an X-Acto knife and glue it together.
Step 5: Raspberry Pi.
After you've designed it, printed it, cut and glued it it's time to put it in the raspberry pi over the heatsinks. I had to make some small adjustments to mine and I also glued the fan to the top of it.
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    3 Comments
    Try 3d printing a case, and the fan shroud! It would look much cleaner! Anyways goodjob!
    Nice job with your build - thanks for sharing it on instructables. What do you think you are going to publish next?
