Introduction: Raspberry Pi GPIO From Phone
Control Raspberry GPIO from Phone application. Through this, you can make your own Remote light switch 220V or FAN, etc.
Step 1: Make Local Web Server
1.1. Install WiringPI
WiringPI is used to control GPIO. On Raspberry, open command to install WiringPI:
$ sudo apt-get install git-core
$ sudo apt-get update
$ sudo apt-get upgrade
$ git clone git://git.drogon.net/wiringPi
$ cd wiringPi
$ git pull origin
$ cd wiringPi
$ ./buildChecking after installation WiringPI
$ gpio mode 0 out
->If nothing special appears, everything's fine.
Sample command, write and read pin 1
$ gpio write 1 0
$ gpio read 1
1.2. Install web server:
To install web server, type command
$ sudo apt-get install apache2 php5 libapache2-mod-php5
If everything OK, a local web will display when you type address to Web Browser 192.168.1.71/index.html
1.3. Make PHP page to interface GPIO
Now we have WiringPI to control GPIO from command, we have web server. So, to use Web server control GPIO, we need make PHP page to control GPIO through WiringPI
In Raspberry:
$ cd /var/www/html
$ gedit io.php
Then paste the code as in this link
Note, this code i made for GPIO7, GPIO8, GPIO9
Step 2: Make Simple Circuit
Using bread board, some wires, resistor 220Ohm to connect GPIO7, 8, 9 to LEDs
Step 3: Control GPIO From Web Browser
Here we go, open Web browser, paste this address http://192.168.1.71/io.php?pin=70
Then, GPIO7 will off, to ON it, past address http://192.168.1.71/io.php?pin=71
Step 4: Control GPIO From Phone Apps (Android)
There is an Android App can be used to send php command. The App can be found in Google Play by keyword "Data2Server" or by this link
In this App, you will configure php address, command for GPIO ON and OFF. Also input IP address to Ping from Phone to Rasp for checking connection.
That's it! Now GPIO can be controlled from your Phone! By this, you can use it for control Light 220V or anything you like!
9 Comments
please i want too the pi where thee pi serves as the admin and andriod sreves as the user
i didn't get your mean. Here, Pi is sever (admin), android is user
The thing is all about when you send information from de andriod the pi will recieve a notification for it to be displayed on to screen.
Almost same with this project, but you need do more:
(1) Local web server (in Pi) receive command from user (Android phone)
(2) Web server show result (you should use local variable to save result status)
Here is another example for light switch where switch status is shown on local web
http://engineer2you.blogspot.com/2016/06/raspberry-pi-remote-light-switch.html
in the 1.3 part
did u mean
$ edit index.html ??
i cant eddit the file
where should i copy and paste the code??
Hi Mr. Lazzy,
copy the code to file io.php
Code is in this link (Google share) https://drive.google.com/drive/folders/0B1UeJfx4pZ1GU0hta0c4LUpnV1E
oh ok i had some troubles with gedit so first i did
$ sudo apt-get install gedit
and then
$ sudo gedit io.php
i am beginer so it was verry dificult to find out why i was not able to edit the file...
thanks everything is working now
Glad to help you.
Whole step also can be view at my blog
http://engineer2you.blogspot.com/2016/09/raspberry-gpio-from-phone.html
