Introduction: Raspberry Pi Halloween Lights and Music Show
This year my house was illuminated and animated by spooky music thanks to the Raspberry Pi. Back in 2009 I created what I called the x-mas box which housed 8 solid state industrial relays connected to an arduino. For this year I repurposed the box and used the Raspberry Pi instead. The lights and music where triggered by a PIR motion sensor.
The show was part of my SMS Magic Mirror with Automatic Candy Dispenser project (Instructable not ready yet, stay tuned).
Step 1: Materials
- Raspberry PI
- USB Wifi dongle
- Adafruit Rapsberry PI prototyping board
- PIR Motion Sensor
- Solid State Relays
- 4 Flood lights
- 4 Flood lights sockets
- 1 Strobe light
- PVC pipe elbow fitting
- Speakers
- Cables
Step 2: Hardware Setup
Check out instructions on how I build the x-mas box here.
For this project I decided to only use 4 of the 8 solid state relays. I connected them directly to the RPI GIO ports and ground. I used the PVC pipe elbow fitting to limit the radius the motion sensor had. This helped to reduce "false positive" triggers since the PIR motion sensor can be quite sensitive.
I used a long cable to let me place the motion sensor close to the ground (the ssr box was placed on the balcony).
Thats basically it. I used the RPI GPIO ports
I placed the 3 flood lights on the second floor deck pointing upwards to allow reflection on the walls. The strobe light was placed in the first floor and it was turned on during the whole song duration.
I connected a set of powerful speaker into the RPI mini-jack audio out.
- 17 strobe light
- 18,21,22 flood lights.
PIRmotion sensor
GPIO 23
3.3v
Ground
Step 3: Software Setup
The program is made with Python and is pretty straight forward. I created functions defining each channel (on/off) and just loop the functions while the mp3 was playing. This was really nice since I used python's "subprocess.Popen" and allowed me to poll the process and know when to stop. The lights danced as long there was music!
I added 5 mp3 songs and they played on a random order.
#!/usr/bin/env python from time import sleep import os import RPi.GPIO as GPIO import time import subprocess from random import randint GPIO.setmode(GPIO.BCM) GPIO.setup(23, GPIO.IN) GPIO.setup(17, GPIO.OUT) GPIO.setup(18, GPIO.OUT) GPIO.setup(21, GPIO.OUT) GPIO.setup(22, GPIO.OUT) init = True def all(): GPIO.output(18, True) GPIO.output(21, True) GPIO.output(22, True) sleep(.3) GPIO.output(18, False) GPIO.output(21, False) GPIO.output(22, False) def one(): GPIO.output(18, True) sleep(.3) GPIO.output(18, False) def two(): GPIO.output(21, True) sleep(.3) GPIO.output(21, False) def three(): GPIO.output(22, True) sleep(.3) GPIO.output(22, False) while True: if ( GPIO.input(23) == True ): print "Motion Detected" if (init == True): print "Initializing for 10 seconds" init =False sleep(10) i = randint(1,5) song = "/home/pi/" + str (i) + ".mp3" reccmd = ["/usr/bin/mpg321", "-q", song] p = subprocess.Popen(reccmd, stdout=subprocess.PIPE) GPIO.output(17, True) while (p.poll() == None): all() one() two() three() all() three() two() one() all() one() two() three() all() three() two() one() one() two() three() one() two() three() one() two() three() one() two() three() GPIO.output(17, False) sleep(5); sleep(30);
Halloween Decorations Contest
DIY Audio
Make It Glow
