Raspberry Pi IoT Doorbell
16,903
97
31
Posted in TechnologyRaspberry-pi
Introduction: Raspberry Pi IoT Doorbell
This Raspberry Pi, IoT Doorbell is basically a simple smart Door Bell, which takes a photo of whoever rings it, and emails it to the specified email address, and keeps all the photos in a folder. (along with going Ding-Dong). This is my first Instructable so I hope you enjoy :)
How I have set out setting this up is: OLD:
the camera is looking at the door bell. I couldn't have the camera above the box because my lead is not long enough
If you wish to use the pi camera instead of a webcam:
nodes19chamb and MichaelM1252 have commented some code that should help! Thx guys.
-----UPDATE!!----
I have Got a new setup where the Button Cable is routed through a small gap in a window next the frount door where the camera taped so it is looking out the window,
PS: The camera quality in my examples is bad because I have a bad camera.
Step 1: Parts/ Tools
Here is the list of parts with approximate prices and links, though you don't need to buy these exact parts
NOTE: :Project costs around $110, Though price can be made cheaper/ more expensive depending where you buy the parts, or using an RPi 1/2.
ALL PRICES ARE IN AUD,
Raspberry pi $55, I've linked Raspberry pi 3, though any should work, though you will need a Wifi adapter if you wish this project to be wireless. You can also use the Raspberry pi 1 B and save $20
Wi-Fi Adapter $10You don't need this if you're using ethernet or RPi 3.
Pi Case $14You don't need this but i recommend it so your pi doesn't get damaged.
Mini Breadboard $1.29 to do wiring on
Button $1.29 (waterproof, Normally Open)
Lengthy wire, to from pi to doorbell
1K resistor, $2.48required for button circuit (only one needed)
Bread Board Jumper Cables $5.19 - you only need 3 :)
Webcam $4 - $100
Box to hold button in $2-10
_____________
Tools:
Soldering Iron (Recommended)
Wire Stripers
Side Cutters/Sharp scissors
Computer
Internet
Step 2: Setting Up Hardware.
IMPORTANT:
I made some mistakes:
It is 5v not 3v
It is 10K Resistor not 1K
If you are using a non B+ Model
you will have to use GPIO 7 (or other) instead of 21!
Hardware is pretty simple. Plug your Webcam into the Rasp-pi, along with your selected network interface. Then, using the images as a guide (the wiring diagrams + this pinout for rasp pi 1B), connect your button and resistors to the pi. With the breadboard image, the orange and blue wires are the wires running the the door bell (Project Box with button).
Step 3: Making the Door Bell
To Make the door Bell you will need to cut a 12mm (1/2") hole in the centre of the project box, and around a hole near the bottom for your wires. Im my case I have taped over the bottom hole(and wires) to stop water from coming in.
Step 4: Software & Programing
Now This is the harder part. First off SSH into your Pi (Raspbian Wheezy or Later).
--- Wondering how to SSH?
here you can find instructions by Antares72 for setting up SSH on Windows with the Pi
Or see here for instructions for Linux or Mac users.
________________________________________
For the "Advanced Users, I have put comments in the code explaining how it works
Follow these instructions (Once in the command line) (copy exactly
Remember to NOT copy the " $ " in these commands if you are copy and pasting.
First, make sure your in your home directory (or whatever directory you wish to install the program to ( PS: it is contained in one folder, so it won't go everywhere in your home directory)
$ cd ~
Then we want to download the dbell folder containing all the code:
$ git clone https://github.com/Happypig123123/dbell.git
Now we want to CD into the directory
$ cd dbell
$ mkdir photos
-------VERY IMPORTANT!!!!!! -------
# NOTE: If you do not use B+ Model, you will need to change the "Button" variable in bell.py from 21 to a # pin number that's available on your pi. TO do this do
# $ nano bell.py
# and change the Button = 21 line to something like Button = 7
# Pinouts are on the "Setting Up Hardware" Setting Up page
Now our setup is time to start editing the email code.
Step 5: Gmail Setup
Gmail?
To be able to send an email with a photo, the raspberry pi needs its own email account. For this we use GMAIL. So click here to sign up for a Gmail account. You can use one you have already created, but you will not be able to receive the notification, that someone is at your door, with it. Also, we will be disabling some security features, making your account more vulnerable to hackers. Step 1a: To Google, the raspberry pi is an "Insecure" Device, so we need to let Google let unsecured devices, (i believe this means devices not using https) login. To do this we:
1. Follow this link (opens in new tab), and log in with your "raspberry pi's" Gmail account you just created.
2. Scroll down to the bottom of the page and you'll see an "Allow login from less secure apps" card. Click the switch to change it to yes. (image of no state above)
Step 6: 3.5.6) Email Script Customisation
Ok Now we setup the Gmail account we can now set up the Email Script. I would like to give credit to Gagandeep Singh, for his code is used in the IoTNotify script, And Sentdex, for his tutorial on python email tutorial, which allowed me to understand the process.
For the more advanced users who want to know how this works, Check out Sentdex's tutorial as I have not explained at all how this script works.
Now do this:
$ nano IOTNOTIFY2.py
and change the following values:
Do this for all of the Fields
to the Gmail account email address E.g: exampleIoT@gmail.com
Yeah, Ass-Word, Wops, Spelling Mistake...
to the email you want to be notified at (eg: your personal email that on your phone, so your phone goes "Buzz" When someone's at the door)
After you have changed all the values, press Ctr X, then Y to save the document
Step 7: 4) Running the Code
Do
$ python3 bell.py
And the script will repeat forever until you press Ctrl Z or Ctrl C
If there is any problems with the script, or i did something wrong, feel free to leave your feed back below (in comment form)
I hope you enjoyed this instructable :)
2 People Made This Project!
  • Spotless Contest
    Spotless Contest
  • Microcontroller Contest
  • Space Challenge
    Space Challenge
31 Comments
After some time I am back onto this project. Cat trashed it last year and I have only just gotten back to it. Waiting on new Pi to arrive as it got fried when cat knocked it off the bench. Is it just the warmth of technology or do they really want to give it a go?
i have this error please help to solve
what should i do
Email
Traceback (most recent call last):
File "IOTNOTIFY2.py", line 29, in <module>
server.login('mewada72894@gmail.com','myoldjeans')
File "/usr/lib/python3.4/smtplib.py", line 652, in login
raise SMTPAuthenticationError(code, resp)
smtplib.SMTPAuthenticationError: (534, b'5.7.14 <https://accounts.google.com/signin/continue?sarp=1&scc=1&plt=AKgnsbv8\n5.7.14 I7caO_mMTlDCB5rUCEs-jGeqFe5ueUJTU75ApgdYJe-xePRmstwRm6bYLxKfnUC4NfAzAK\n5.7.14 TXC0QiaEdSNSsQQaQWR_cP43lU91PLFtnHaYHlz4Sr-9btEp8xdG-p_31EipeApWRTtXKu\n5.7.14 CxQiMALZSOj3VX80HsM332g4LCFnKyXulB-DMwhFZLy64XmiC9iQCpwNXFSBLfgjwQI7yO\n5.7.14 rNc2kyoDRxQxkYYTMMSqZt4kjVyUA> Please log in via your web browser and\n5.7.14 then try again.\n5.7.14 Learn more at\n5.7.14 https://support.google.com/mail/answer/78754 y6sm21630291pgc.40 - gsmtp')
Done Process
Hi, I have since updated the email account process above, thank you for posting this error though, as you have made me aware of this issue, which I have now fixed, so more people can use this project :). Here is how to fix your issue:
Also, we will be disabling some security features, this may make your account more vulnerable to hackers, so I recommend making a new account. Step 1a: To Google, the raspberry pi is an "Insecure" Device, so we need to let Google let unsecured devices, (i believe this means devices not using https) login. To do this we:
Darmish Did you get this working?
Looks like an authentication error on gmail
BTW did you change your password? You gave your password "Myoldjeans" away while cutting and pasting.
I would like to continue this project so I am interested in what others have done.
Thanks MM
Hi Darmish, I will have a through look today. To help could paste in the contents of IOTNOTIFY2.py in here so I can see what changes you've made. (That the Instructables asked you to do). Before that make sure you've filled out all the fields
does the end user have an interface where he/she can add/edit the email address considering that the end user has no python skills
No, this tutorial I believes steps you through on how to do this. This is just meant to be a simple python project to get people's skills up.
how do i remove the loop
so that it does not auto press itself
you need the loop to look for the button press, if it is auto "pressing" then change the value on line 13:
if GPIO.input(Button) ==False: #when button pressed
change false to 1 or true, if this dosen't work,you have wired the button incorectly.
is there a code that i can run to make the doorbell make a live video call to the end user
you can use a program called motion, that makes the pi into a live stream camera, then you can have the doorbell just notify you with a link to the stream. please note though, without port forwarding, this will only work in the LAN of the pi, here is a link to a tutorial (note i have not teied this exact tutorial myself) http://www.techradar.com/how-to/computing/how-to-build-a-raspberry-pi-security-camera-1321441/2
Linux raspberrypi 4.4.11-v7+ #888 SMP Mon May 23 20:10:33 BST 2016 armv7l GNU/Linux
PI3
It is a while since I did this, but i found i needed to change the mode by reading
raspi.tv
/2013/rpi-gpio-basics-4-setting-up-rpi-gpio-numbering-systems-and-inputs
RPi.GPIO basics 4 – Setting up RPi.GPIO, numbering systems and inputs
in bell.py it is changed to look as
#GPIO SETUP
GPIO.setmode(GPIO.BOARD)
Button = 21
I love this made it on Pi3
changed the gpio setup to BOARD
Thanks for all your information you've put down here about using the pi camera instead.
I'm getting the following error when I run the python file:
File "bell.py", line 6, in <module>
GPIO.setmode(GPIO.BCM)
AttributeError: module 'RPi.GPIO' has no attribute 'setmode'
I've tried everything. Please help, urgent!
Hi Jaimish. I made this on Pi3 but changed
Hi JamishA, I think the problem is on your side. What version of the raspberry pi do you have, and what version of raspbian is it running? And have you done any other projects using the GPIO pins on the pi? Then, I will be able to have more information on how to solve your issue. Thx, Angus.
Hi JaimishA, I am currently away from my PC, so in around a day or so I should get back 2 you with the answer to your problem
