Introduction: Raspberry Pi + Node.js + Blynk App + DHT11/DHT22/AM2302
About: Blynk Co-Founder, Senior Engineer, Public Speaker, Dreamer and Doer
This time we will display some sensor values (DHT11 in example) on the Smartphone using Blynk App.
You will need:
  1. Raspberry Pi with internet connection
  2. Temperature and humidity sensors: DHT11 or DHT22 or AM2302
  3. Jumper wires
Please check my tutorial about getting Blynk and Node.JS running on Raspberry Pi and other single-board computers (BeagleBone, Intel Edison, Galileo, VoCore, OpenWrt... ):
After you get Blynk JavaScript library running, we can move on to reading sensor values.
Step 1: Install Sensor Libraries
For DHT11/DHT22/AM2302 sensors, you need to download and install:
Here are the commands I run on my Raspberry to do this (it may take some time to execute...):
wget http://www.airspayce.com/mikem/bcm2835/bcm2835-1.46.tar.gz
tar zxvf bcm2835-1.46.tar.gz
cd bcm2835-1.46
./configure
make
sudo make check
sudo make install
sudo npm install -g node-dht-sensor
Note: You may want to read the node-dht-sensor Readme, and run "First Example" ;)
Step 2: Scan/create Blynk Project
After logging in to the Blynk App, you can scan the QR code and get the project I have prepared for you (only Android, for now...).
Alternatively, you can create it manually:
  1. Create a new dashboard of type Generic, and send yourself an Auth Token.
  2. Add a Graph widget and bind it to V3
    Set range to 10..40,
    reading frequency to "PUSH"
  3. Add a Value Display widget and bind it to V4
  4. Press Run (triangle in the upper right corner)
Step 3: Blynk Script for DHT11
Wire Raspberry Pi and DHT11:
  • GND to GND
  • sensor Signal to gpio4
  • sensor VCC to 3.3v
On the board, create a new file (call it blynk-sensor-test.js):
var blynkLib = require('blynk-library');
var sensorLib = require('node-dht-sensor');
var AUTH = 'YOUR_AUTH_TOKEN';
// Setup Blynk
var blynk = new blynkLib.Blynk(AUTH);
// Setup sensor, exit if failed
var sensorType = 11; // 11 for DHT11, 22 for DHT22 and AM2302
var sensorPin  = 4;  // The GPIO pin number for sensor signal
if (!sensorLib.initialize(sensorType, sensorPin)) {
    console.warn('Failed to initialize sensor');
    process.exit(1);
// Automatically update sensor value every 2 seconds
setInterval(function() {
    var readout = sensorLib.read();
    blynk.virtualWrite(3, readout.temperature.toFixed(1));
    blynk.virtualWrite(4, readout.humidity.toFixed(1));
    console.log('Temperature:', readout.temperature.toFixed(1) + 'C');
    console.log('Humidity:   ', readout.humidity.toFixed(1)    + '%');
}, 2000);
Replace YOUR_AUTH_TOKEN with your token from the App.
You may also want to change sensorType and sensorPin.
Now run it:
sudo NODE_PATH=/usr/local/lib/node_modules node ./blynk-sensor-test.js
The output should look like this:
OnOff mode
Connecting to TCP: cloud.blynk.cc 8442
Connected
Temperature: 18.0C
Humidity:    26.0%
Temperature: 18.0C
Humidity:    26.0%
Note:
  • You need to run our script with sudo as the sensor library requires privileged access to the hardware
  • NODE_PATH=.. is set because Node.js may fail to locate global modules otherwise
Step 4: Enjoy Sensor Values in the Blynk App
Now, check the Blynk App on your smartphone, it should display a nice plot of temperature and current value of humidity. Congratulations! ;)
