Raspberry Pi On/Off Switch With Status Light
Published
Introduction: Raspberry Pi On/Off Switch With Status Light
This project will make a button switch that will both boot up and shutdown a Raspberry Pi and will light an LED while the RPi is operational. Great for headless setups. I created it to augment a Raspberry Pi Baby monitor, because of the concern with using a camera in a shared room.
My example is on a Raspberry Pi Zero, but it will work on any Raspberry Pi.
I used the MakerSpot Prototyping Hat to install it on.
Step 1: Solder Board
The button switch is just Pin 5(GPIO3) and 6(GND) connected together. I added a .01uf capacitor because it would signal the GPIO without hitting the button especially when I discharged static electricity nearby. Works reliably with the capacitor.
The LED is hooked to ground with a 330 Ohm resistor and is powered by the TXD (Pin 8). It needs serial console enabled to Light up. My circuit board pictured is a little different from this guide because I was in the process of adding some IR LEDs to my project.
Step 2: Raspbian Configuration
It needs a service to shut it down when you press the button.
Download python script
wget -O off.py https://cdn.instructables.com/ORIG/FZE/8MLV/JF343EG3/FZE8MLVJF343EG3.py
Make off.py executable
pi@raspberrypi ~ $ chmod +x off.py
Setup startup service
pi@raspberrypi ~ $ sudo nano /lib/systemd/system/off.service
[Unit] Description=Off Program
[Service]
ExecStart=/home/pi/off.py
StandardOutput=null
[Install]
WantedBy=multi-user.target
Alias=off.service
Save, then active the service
pi@raspberrypi ~ $ sudo systemctl enable off.service
pi@raspberrypi ~ $ sudo systemctl start off.service
It also needs serial turned on
pi@raspberrypi ~ $ sudo raspi-config
Step 3: Finished Project
I added this to a RPi Baby Monitor
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
