Raspberry Pi - Plex Media Server
6,762
84
Published
Introduction: Raspberry Pi - Plex Media Server
About: IoT Related Projects
The Raspberry Pi is a small piece of development hardware that runs various different operating systems and has a large number of GPIO pins that make building DIY projects with the raspberry pi possible. The raspberry pi has different versions of boards available. For this tutorial we will be using the Raspberry Pi 3 (It has onboard WiFi and lot more), you could also do the same on a Raspberry Pi 2.
For this instructable I will be showing you how to set up a media center on the Raspberry Pi to stream content to different devices. For the media center we will be using Plex which is a popular software and different devices for playback.
Step 1: Tools and Components
For this instructable you will need
  • Raspberry Pi 3 (You could also use Pi 2)
  • HDD
  • MicroUSB
  • 5V 2A Power supply
Step 2: Connecting to Internet
Before we get started using Plex we need to connect the Pi to the internet and enable ssh (Optional). To connect the Pi to the internet I would recommend using Ethernet over the onboard WiFi, this would give better streaming experience while steaming in HD.
The Raspberry Pi OS is stored on a micro SD card, you need to install Rapsbian for this tutorial.
To enable ssh you will need a mouse, a keyboard and a HDMI monitor. Connect all the devices to the Pi and power it on. Then enable it in settings under interfacing.
Step 3: Installing Plex
First lets start of buy updating the Pi to the latest repositories, you can do so by typing in the below commands.
sudo apt-get update && sudo apt-get upgrade -y
Next lets install a HTTPS transport package for using HTTPS
sudo apt-get install apt-transport-https -y --force-yes
To install Plex you will an software download key we will use wget to access it.
wget -O -  https://dev2day.de/pms/dev2day-pms.gpg.key   | sudo apt-key add -
Next lets add Plex to our repository so we can use apt to install the software in the next step.
echo "deb https://dev2day.de/pms/ jessie main" | sudo tee /etc/apt/sources.list.d/pms.list
Step 4: Installing Plex Part 2
Now that you have added Plex to the raspbian repositories you can install it using
sudo apt-get update
sudo apt-get install -t jessie plexmediaserver -y
This would take a few minutes, so grab a cup off coffee while you wait.
Once you go Plex installed reboot your pi by typing in
sudo reboot
Once the Pi is booted up use the below command to note the IP address of your pi
hostname -i
Now visit the URL to access Plex
<your pi ip>:32400/web
Step 5: Going Further
Once you have got Plex installed you need to add in some media content to stream, I connected an external HDD to the PI via USB port. You could do the same or you could get a sata to USB converter and use a internal HDD instead.
Now you can add media content on to your drive and Plex updates each time it scans for any new content.
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Planter Challenge
      Planter Challenge
    3 Comments
    Hi I have tried installing following the instructions and when I get to the stage sudo apt install Jesse plexmediaserver I get the following error code
    The value Jessie is invalid for APT::Default release as such a release is not available in resources
    Help me please Obiwan !!
    Can it transcode ?
    Becous they recommend a pasmark score of 3000-4000 for 1user
    Depending on movie size 4k to a few Mbit is a lot of work
    I use emby on a i3 7100 works fine
    Also works on a i5 650
    Not on an old laptop Pentium dual-core t2390 1.86ghz
    Can it handle more than one viewers, if so how many?
