Raspberry Pi Portable Arcade Console (with RetroPie)
Published
Introduction: Raspberry Pi Portable Arcade Console (with RetroPie)
Find out how to make an easy portable arcade console (cabinet) using a Raspberry Pi! You can bring it anywhere, plug it into any tv, and play all your favorite classic ROMs. This arcade has 4 general buttons and a joystick, but you can also plug in any old usb enabled controller.
Step 1: Materials
You will need a few materials to build this project:
I've also modeled a 3d printable case that you can use if you have access to a 3d printer.
3D Printable Files
If you don't have access to a 3d printer, you will need some tools:
  • Drill
  • 1-1/8" Drill Bit
  • 1/2" Drill Bit
  • Sand Paper
For wiring, you will need:
  • Soldering Iron
  • Solder
  • Wire Strippers
Step 2: Instructions
I created a 24 minute step-by-step video on how to assemble the arcade console, load the emulation software, map GPIO buttons to USB, and install ROMs. I'm using RetroPie for the emulators and Adafruit's Retrogame executable to map GPIO buttons to USB. RetroPie is great because it works with many different ROM files.
Step 3: Diagrams and Resources
On the Github repository for this project, I've added all of the diagrams for wiring. I've also posted my modified retrogame.c file.
(*note - joystick diagram provided by Adafruit)
That's it! If you have any questions about the project, please post them in the comments and I will answer them the best I can.
Thanks,
Aaron @HackerHouse
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    3 Comments
    Hello,
    Really cool project. Is there a way to add more than 4 buttons in order to emulate controllers with more controls? I was thinking of using it for SNES but would need an extra 4 buttons past what you have there.
    Thanks.
    Yep, just plug the wires into any open gpio pins and add an entry in the retrogame.c file. You can also connect the ground wires together if there aren't enough ground pins.
