Introduction: Raspberry Pi Radio Transmitter
Recent Update(02/14/19):
These instructions are no longer up to date and should not be used with any pi besides the original RPI. Please proceed with these instructions at your own risk regardless. Read the comments to see what other people are having issues with before starting. I am no longer answering questions about this instructable. Thank you for reading and good luck.
The Raspberry Pi is a very useful computer that can be used for many different things. The people over at Imperial College Robotics Society have a new way to use your favorite treat. They designed a program that turns the Pi into an FM radio transmitter. This instructable will show you how to make your own Pifm transmitter, installing and using the program.
Some Updates (03/11/15):
There is a new program up that I wrote where you only need the filename (NOT THE PATH). It will install everything for you, all you have to do is type in the frequency and the filename to be played (WAV or MP3, stereo or mono). github.com/CodyJHeiser/PiStation
ICRS has released another version on PiFM a while back, it allows you to play stereo sounds (mp3 files) over the radio now. You can go to this link here to check out the new information (the new code is included in my program listed above.)
More Updates (08/06/15):
The member, AndrewG29, has given me a link to GitHub that supports the Raspberry Pi 2! Through the traditional method, this doesn't work on the RPi2.
Step 1: Having the Necessary Parts
1. Raspberry Pi
2. 5 volt 1 amp (between 750 milliamps and 2 amps is what I have tried) USB power supply
3. Micro USB cable
4. At least 2 GB SD card with Raspbian on it
5. A display or ssh
Now past the basics, you will need these items as well for it to work.
1. Ethernet cable or a wifi dongle (See step two if you don't have this)
2. Some sort of antenna
You can just use your finger but it will not work as well, you can use a Pi Cobbler with some wire sticking out of the pin like I did, it works fine, the projected range is about 10 meters, but I found it to go much longer than that.
Step 2: Downloading the Packages
** If you have an Ethernet cable you can ignore this paragraph. If you don't have an Ethernet cable but you still want to do this you can download the files onto your computer and put it on a flash drive and upload it to the "pi/home" directory.
Now in your Pi terminal type in this exactly, pay attention to capitalization!
wget www.icrobotics.co.uk/wiki/images/c/c3/Pifm.tar.gz
(Capitalized 'P' in 'Pifm.tar.gz')
ls
(If you did it right when you type 'ls' you should see other files along with one named, 'Pifm.tar.gz')
tar -xvf Pifm.tar.gz
(Again, capitalized 'P' in 'Pifm.tar.gz')
That's it! All of the code is done, now on to the next step to learn how to actually play music over any station you want.
Step 3: Using the Software
There are a few commands that are used to control the pi I will list them below and break them up and tell you what they mean step by step.
Before we get into the code, you need to know what pin it broadcast's out of so you can attach your antenna to it. GPIO pin 4 is what is being used, unfortunately you can't change the pin number because it have specific specifications embedded into it, so if you have something else running out of GPIO pin 4, you will have to change it or take it out for this to work.
sudo ./pifm sound.wav 100.1
sudo - This gives you administrator power (like on windows the admin)
./pifm - The ./ is used to run a program, the program you want to run is what you put after it (pifm)
sound.wav - Here is the music you want to be played over the radio, you can change it to any** .wav file
100.1 - This is the station that you want your music to be played on, you can change this to anything between 87.1 and 108.1
To exit your song press, 'control' + 'c'
If you have a microphone you can plug it into the USB port and broadcast your voice over the radio station here is what you will type in:
arecord -fS16_LE -r 22050 -Dplughw:1,0 - | sudo ./pifm - 100.1 22050
(pay attention to capitalization)
To do this of course you have to have a USB microphone, I have an old Wii Karaoke microphone that works just fine. You can just pick one up off Amazon to, I just found a Guitar Hero one for about $15 here.
Step 4: Adding Other Songs
So you probably don't just want one song on your Raspberry Pi. To put the songs that you want onto it you have to have the correct format. It has to be a .wav file and if you have a .mp3 file or .mp4 or whatever, you need to convert it. You can use this online one here. It also has to be in 16 bit : 22050 Hz : mono. If it is not like that it will sound really slow and weird or really fast and weird.
UPDATE: There is now a way to use .mp3 files in your raspberry pi, here is a Google Doc for more information.
https://docs.google.com/document/d/1URn_9QpnP9CjUq9fpjuMdpL6svTr8hoGThmilHePV5g/edit?usp=sharing
To import your song just use an FTP server like Fillzilla, you can find a pretty good tutorial on it here. Make sure you import it to the home/pi directory (it is on it by default) to avoid extra work. As far as the code just replace the 'sound.wav' with the name of your song.
EX. sudo ./pifm livin_on_a_prayer.wav 100.1
If your song has spaces in it you may notice that it doesn't work, it will give you an error, to fix this put the name of the song in quotes.
EX. sudo ./pifm "living on a prayer.wav" 100.1
TIPS -
Make sure that you are capitalizing what you are suppose to
Be sure to spell everything right
You can see all of the songs that you downloaded by typing 'ls' in the command line
Any other questions, don't be afraid to leave a comment!
