Introduction: Raspberry Pi Talking Barcode Reader
Fig.1 Barcode Scanner from DX.com
Overview
Update: A short video demo is available https://youtu.be/b905MLfGTcM
My mom is unable to read labels on grocery items anymore, so I went looking for solutions. After seeing that bar code readers for the blind run many hundreds of dollars, I wanted to see what could be done using a Raspberry Pi and a USB Barcode reader.
Another key imitation was that this should work WITHOUT an Internet connection (such as at a store or friend's house). So the database and text-to-speech had to be self-contained.
I tried a camera based version of bar code reader, but lighting and camera position caused reliability issues for someone unable to see clearly. These also required sight to set up and use the app. So I switched to a USB Laser bar code reader, especially since they are now available for under $30 and the Raspbian Jessie supports them right out of the box.
I also tried out the new Amazon Dash Wand but it does not speak the scanned item and it requires an Internet connection to work.
The idea was to scan an item and have the Raspberry query an internal database of UPC codes and then speak the product description using text-to-speech.
In order to make the unit as small as possible, I wanted to use a Raspberry Pi Zero. I also wanted to run the unit off battery power as well.
To meet these requirements some tradeoffs were necessary. Since the Zero doesn’t have an external audio jack I reused the audio design from my “Earthquake Pi” project as it was low cost (about $6) and very small. Alternately, substituting the "One Transistor Audio for Pi Zero" may be possible.
For the Laser Bar Code scanner, I found one from DX.com. It is powered off the Raspberry USB and costs about $25. (see Parts below)
Step 1: UPDATE
With the arrival of the Raspberry Pi Zero W, I am going to switch to it. Everything here is the same, except that you need to set up the WiFi connection to the Pi. This means that you won’t need a USB hub for the Zero for setup and use.
You can set up the WiFi using:
https://thepihut.com/blogs/raspberry-pi-tutorials/...
Did you know?
If you install Raspbian Jessie on an SD card using a Windows PC, you can create two files on the card to configure WiFi and SSH access before you boot it on a Raspberry?
For this, assume your SD card is currently mounted as K: on your PC:
1) Install the latest Raspbian Jessie image to the SD. For this project, Jessie Lite should work.
https://www.raspberrypi.org/downloads/raspbian/
2) With notepad, create a file called just “ssh” and use Save As “All files” to K:\ssh
The file can contain anything. It’s the filename that is important. Must NOT be “ssh.txt”!!!
3) With notepad, create a file called “wpa_supplicant.conf” with following:
<p>ctrl_interface=DIR=/var/run/wpa_supplicant <br>GROUP=netdev<br>update_config=1</p><p>network={
ssid="mySSID"
psk="mypassword"
key_mgmt=WPA-PSK
}</p>Use Save As “All files” to K:\wpa_supplicant.conf
Again, do not let Notepad change it to “wpa_supplicant.conf.txt”!!
When you boot the Raspberry the first time, Jessie will look for these and connect to your Wifi. You will have to look on your Router for the IP address, though, since its auto assigned.
Step 2: Parts List
- Raspberry Pi Zero (or any Raspberry Pi, if size isn’t an issue)
- USB Laser bar code scanner
- For Raspi Zero, add Adafruit I2S 3W Class D Amplifier
https://www.adafruit.com/products/3006 - Small speaker. (For Pi 2,3, use external amp & speaker.)
https://www.adafruit.com/product/1890 - USB Micro to USB OTG adapter
https://www.adafruit.com/products/2910 - 5V 1Amp USB battery pack such as
https://www.adafruit.com/products/1959 - USB to micro USB cable for battery pack.
- USB & Ethernet hub (at least for initial setup work, not needed for Zero W or Raspi 2,3)
https://www.adafruit.com/products/2992 - Software from GITHUB:
https://github.com/rgrokett/TalkingBarcodeReader
Step 3: USB Laser Bar Code Reader
Laser bar code readers are more forgiving in their ability to scan a UPC label than cameras. They also work well even in poorly lit or poorly placed labels.
You will need the USB to USB micro adapter to plug it into the Zero.
The hand grip and trigger of the scanner makes it easy to use.
It also gives feedback when it successfully scans a label.
Future ToDo:
In the final design, I would cut the cable down to shorten it and solder directly to the USB pins on the Zero to reduce the size and likelihood of a connector failure. The Zero and battery would be attached directly to the bottom of the scanner handle in a 3D printed case.
Step 4: UPC Database
This is the most poorly covered part of the project, as there are literally millions of UPC codes and very few open-source databases available for download. Unfortunately, most UPC databases are rather pricy and require internet connectivity.
I was able to put a couple open-source databases together (sources in Appendix below), but even with nearly 700,000 items in it, a vast number are missing.
To this end, I have done two things; one is to focus on grocery items specifically and the other is to add a web server to the Raspberry to allow adding new UPC codes manually, though, this does require at least local network connectivity.
Future ToDo:
I would make the Zero W a "hotspot" so that you could connect to it anywhere to add new UPC codes.
Step 5: Text-to-Speech
I used the text to speech program called “Flite”, as it had the best compromise between voice quality and conversion speed on the Zero. Others sounded a little better, but were too slow to convert.
You can also check out Adafruit’s tutorial:
https://learn.adafruit.com/speech-synthesis-on-the...
Note that it will take a bit of “ear training” to get used to the speech inflection, but it’s not too bad.
Scanning the same item again will repeat the audio.
Future ToDo
Maybe add a headphone jack so to make it easier for seniors to hear the voice in noisy places.
Step 6: Battery Power
The system can be run from a 5V USB battery, such as used to recharge cell phones.
The catch is that when you unplug the battery or the battery dies, the Pi will crash with a chance that it will corrupt the SD drive.
To solve this, a button that runs a shutdown command is needed. I will probably use one like this:
https://www.element14.com/community/docs/DOC-78055...
(Yes... another "Future ToDo!")
Step 7: Part I - Adding Audio to Pi Zero
(Skip this part if not using a Zero!)
On a Pi Zero, you will need to add external audio, since it’s not built-in. I used the low cost “Adafruit I2S 3W Amplifier breakout MAX98357A”
This requires setup using Adafruit’s excellent tutorial at:
https://learn.adafruit.com/adafruit-max98357-i2s-...
As shown in the wiring part of the tutorial, connect:
• Amp Vin to Raspi Zero Pi 5V
• Amp GND to Raspi Zero Pi GND • Amp DIN to Raspi Zero Pi #21 • Amp BCLK to Raspi Zero Pi #18 • Amp LRCLK to Raspi Zero Pi #19
Connect a small speaker to the audio leads on the board.
Pi Zero Adafruit Audio Software Setup
Also shown in the Adafruit software setup tutorial, execute the CURL command below:
$ curl -sS https://raw.githubusercontent.com/adafruit/Raspbe...> | bash
After the reboot, test the audio using speaker-test:
$ speaker-test -c2 --test=wav -w /usr/share/sounds/alsa/Front_Center.wav
If you have problems, go back thru the Adafruit tutorial starting back at the overview. You may need to go thru the “Detailed installation” steps in the tutorial to verify all the files updated.
Important Required Steps for Zero & Max98357 Audio:
By default, the ALSA audio only works in Stereo while Flite text-to-speech is mono. Also, the audio has “pops” in it every time it starts playing.
(See: https://learn.adafruit.com/adafruit-max98357-i2s-...
You must do the following:
1) Append a line to /boot/config.txt
$ sudo nano /boot/config.txt dtoverlay=i2s-mmap
2) Replace /etc/asound.conf
$ sudo nano /etc/asound.conf
pcm.hifiberry {
type hw card 0
pcm.!default {
type plug
slave.pcm "dmixer"
pcm.dmixer {
type dmix
ipc_key 1024
slave {
pcm "hifiberry"
channels 2
ctl.dmixer {
type hw
card 0
}3) Reboot your Pi.
Try the Speaker-test again. It should sound better now.
Once you complete the setup tutorial including the audio tests, then sound should be ready.
Note that you may want to add an earphone jack for audio, if you take this to a grocery store or noisy environment.
Step 8: Part II – Software Installation
This assumes you already have Raspbian Jessie installed and can access the Linux command-line. You do not need the GUI version of Raspbian, but is ok to use.
You DO NOT need the USB scanner plugged in at the moment, in case you need the USB port for Ethernet or keyboard/mouse.
Make sure your OS is up to date:
$ sudo apt-get update<br>$ sudo apt-get upgrade
From command-line, go to the pi home directory and download the GITHUB repository:
$ cd /home/pi<br>$ sudo apt install git $ git clone https://github.com/rgrokett/TalkingBarcodeReader....> https://github.com/rgrokett/TalkingBarcodeReader....> $ cd TalkingBarcodeReader $ ./install.sh
This will take some time, particularly if this is the first time and the web server and PHP need to be installed or updated. If necessary, you can run this more than once.
Among other things, this installs the barcode files and UPC database to: /var/www/html/upc
Next, edit /etc/rc.local and append following line before the “exit 0"
$ sudo nano /etc/rc.local fi sudo /var/www/html/upc/bin/run.sh exit 0
Once installation is completed, shut down your Pi and plug in the USB Barcode reader and restart.
$ sudo shutdown now
Power it back up and you should hear a short startup speech.
If so, try scanning a bar code from a grocery item. If all went well, you should hear it speak the item (or speak “Not Found”) . Otherwise, check on the troubleshooting guide next.
Step 9: Troubleshooting
If you don’t hear any sounds, you will need to try the following commands:
1) Verify the text-to-speech audio is working:
$ sudo flite -voice awb -t "testing"
If you get an error, be sure flite was installed:
$ sudo apt install flite
If you get the following error, be sure you updated /boot/config.txt and /etc/asound.conf shown in the Audio Setup section above on Raspi Zero’s:
audio_open_alsa: failed to set number of channels to 1. Invalid argument.
If you get no error and no sound, be sure your Raspberry audio is functioning.
sudo aplay /usr/share/sounds/alsa/Front_Center.wav
1) You may need to force the audio out the audio jack: (see fig.1 above)
$ sudo raspi-config -> 7 Advanced Options -> A4 Audio
2) Once you have audio and text-to-speech verified good, check the barcode reader:
cd /var/www/html/upc/bin<br>sudo python ./test.py
You should see a numeric barcode number displayed when you scan a barcode. (The test program does NOT include audio output or database connections.)
3) If all of this is good, then check the “nohup.out” file for error messages:
cd /var/www/html/upc/bin<br>sudo cat nohup.out
Likely issues are missing packages or bad permissions (or BUGs in the code!). Be sure your OS is up to date and rerun the install.sh again.
Hopefully, you are working by now!
Step 10: Part III – Web Server
Since there are MILLIONS of UPC codes and most publicly (i.e. free) available databases are only a small subset of codes, this project focused on UPC codes for groceries. It includes several hundred thousand items, but many, many will not be found.
If you need to add or update the UPC Database, there are two programs available; a command-line one and a web browser one. (replace the digits with your UPC item number)
$ cd /var/www/html/upc/bin $ sudo ./addDB.sh 01234567890 “My new item”
This will add a record to the database. Otherwise, it is suggested to use the web browser DB function.
For the Web Server GUI, you need the IP address of your raspberry.
To find the IP address, you can use:
$ hostname -I <br>192.168.1.108
From a PC browser, go to: http://192.168.1.108/upc/
You should see a screen similar to the one in Fig.2 above.
If so, you can add/update and delete records.
Navigate to the Last Page using the (‘>|’) “last record” button to see your newest records as they are appended to the end of the database.
SECURITY
NOTE that this web service is not secured, (no authentication, no SSL), so best not to expose it to the public Internet. (But since it’s not set up as a WiFi Access Point, it is safe to carry to the store.)
Though, since there is no private data on it, the worse that could happen is someone mangling the UPC data.
You can also limit access to specific IP addresses so no others can get in. Just substitute the IP(s) here for the ones you wish to allow. All others will be blocked from accessing:
$ sudo vi /etc/lighttpd/lighttpd.conf
$HTTP["remoteip"] =~ "127.0.0.1|192.168.1.108" {
url.access-deny = ( "" )
$ sudo /etc/init.d/lighttpd restartAlso, CHANGE the default PI password!
Everybody knows the default is pi/raspberry
$ passwd
Step 11: Troubleshooting the Web Server
Using your browser go to your Raspberry’s IP address, like this:
You should see the default screen from /var/www/html/index.html (Fig.1 above)
Also be sure that the webserver is running:
<p>$ ps -ef|grep lighttpd</p>
To verify PHP is good, create a php test file:
$ sudo nano /var/www/html/phpinfo.php <!--?PHP phpinfo() ?>
Then go to http://192.168.1.108/phpinfo.php
You should see a screen like Fig.2 above
If you get errors or blank screens, check for errors in
$ sudo cat /var/log/lighttpd/error.log
Again, rerunning the install.sh may fix missing dependencies.
Step 12: Appendix
A BIG THANKS goes to the following for making available a large UPC database.
Open Grocery UPC DB
http://www.grocery.com/open-grocery-database-proje...
Open Data DB
http://www.upc-search.org/perl/upc-search.pl?q=84...
Thanks to EasyUI for the simple web CRUD GUI
