loading
Step 5: Install I2C Packages
Install the i2c-tools and python-smbus packages to complete the I2C setup:
The following commands can be used to install the packages:
sudo apt-get install i2c-tools
sudo apt-get install python-smbus
Finally add the pi user (or whatever login required) to the I2C access group.
The following command can be used to accomplish this:
sudo adduser pi i2c
Use the following command to see what devices are connected to the I2C bus:
i2cdetect -y 1
Note: use the following command if you are using a model A Raspberry Pi
i2cdetect -y0
The I2C address (in hexadecimal) of the temperature sensor should show up if properly connected.
<p>Don't forget to install the python-smbus python module:</p><p>sudo apt-get install python-smbus </p>
<p>without that I got this error on Raspian-jessie</p><blockquote><strong>pi@raspberrypi</strong>:<strong>~/tempsens $</strong> python temp_logger.py<br>Traceback (most recent call last):<br>File &quot;temp_logger.py&quot;, line 6, in &lt;module&gt;<br>import smbus<br>ImportError: No module named smbus</blockquote>
<p>hello</p><p> i had done all the thing but i am using another sensor so i want to know how this calculation of converting in to data is done please expline</p><p>thanks in advance</p>
<p>Hi RobZ314. I'm very green in the Pi business... :-) I'd like to have my Pi bootup and autorun the program without any user intervention. Ie. I'd like to apply only power and have the program run by itself logging the results for some time. Reason for this is that I need the unit to record temperature in a location far from keyboards, monitors, etc. </p><p>Is this possible, or should I make a plan to carry the peripherals with?</p><p>Thank you for your time.</p><p>Regards</p>
<p>I like it. Thanks. I ran into a few different troubles and think I found the solutions Has anyone else had an issue with i2cdetect finding the file? I added these steps and it started working afterwards:</p><p>If you are running a recent Raspberry Pi (3.18 kernel or higher) you will also need to update the<strong>/boot/config.txt</strong> file. Edit it with <strong>sudo nano /boot/config.txt</strong> and add the text</p><p><strong>dtparam=i2c1=on<br>dtparam=i2c_arm=on</strong></p><p><strong><br></strong></p><p><strong><br></strong></p><p><strong>and:</strong></p><p><strong><br></strong></p><p><strong><br></strong></p><p><strong><br></strong></p><pre><ol><li>sudo nano /etc/modules</ol></pre><p>and add these two lines to the end of the file:</p><pre><ol><li>i2c-bcm2708 <li>i2c-dev</ol></pre>
<p>I am still getting the error if I do that...do you know what else I can do </p>
<p>Hi. I am hoping to use the ultimate starter kit to construct an continuous data logging system for pH and temperature. I am an beginner beginner on building raspberry pis and programming!!!</p>
<p>Works great! But I want to connect TWO of these sensors. How do I change the address of the second one?</p>
<p>excuse me sir if i used thermocouple type k ,can it work using your method?? please reply as soon as possible.thx :D</p>
<p>How to set time, date and timezone in raspberry pi without RTC.</p><p>date in my raspberry pi is default, not date now</p>
<p>Thanks a very awesome tutorial, ZRob314<br>Could you show us how to write your logger record to online SQL database like in Windows Azure's Management Portal?</p>
Hey i am also in Toronto. Very cool projects you have. Would you be i nterested In a paid project? Need something done right away.
About This Instructable
147,922views
177favorites
License:
More by ZRob314:Piano Pi - Play a Duet With Your Pi! Raspberry Pi Touchscreen Setup Times Square in your living room!   Turn your Sense Hat LED into a news ticker.
Add instructable to:
