Picture of Raspberry Pi Tor relay
Tor (short for The Onion Router) is a system intended to enable online anonymity. The Tor client software directs internet traffic through a worldwide volunteer network of servers to conceal a user's location or usage from anyone conducting network surveillance or traffic analysis. Using Tor makes it more difficult to trace Internet activity, including "visits to Web sites, online posts, instant messages and other communication forms", back to the user and is intended to protect users' personal freedom, privacy, and ability to conduct confidential business by keeping their internet activities from being monitored.
So obviously, TOR needs a large amount of servers and as TOR network is not a commercial organisation, it requires voluntary supporters. You can be one of them and turn your Raspberry in a TOR relay.
Step 1: Parts needed
You need the following parts:
- Raspberry Pi
- power supply
- network cable/connection to the Internet
- SDcard with Raspbian (you can find all necessary installation intructions here: http://www.raspbian.org/RaspbianInstaller)
Step 2: Let's start
For security reasons you should not work as "root" all the time, you can fix this problem with the following steps:
Open a terminal
    apt-get install sudo
adduser tor
    passwd tor
this creates the user "tor" and let's you set a password. Please use at least 8 digits (numeric, alphanumeric and special characters)
Now we have to to add the tor user account to the list of sudoers:
    nano /etc/sudoers
Add the line
    tor ALL=(ALL) ALL
Now we'll install the latest security patchess and updates. Please do this  regularly!!!
    sudo apt-get update
    sudo apt-get upgrade
Step 3: Network configuration
Now that the base setup is done, we have to configure network interface, open a terminal and use this command:
ifconfig
This shows you your actual configuration:
eth0      Link encap:Ethernet  HWaddr 00:23:54:40:66:df
          inet addr:192.168.0.20  Bcast:192.168.0.255  Mask:255.255.255.0
write down inet addr and mask
then type:
sudo nano /etc/network/interfaces
You will find a line like this:
              iface eth0 inet dhcp
So as we see the Raspberry obtains an IP adress from the local DHCP server. If you want a static IP you hould change this to:
iface eth0 inet static
address 192.168.0.20 <- chose an IP that fits to your network! This is only an example!
netmask 255.255.255.0 <- change to the settings that fit to your network
gateway 192.168.0.1  <- type in the correct IP adress of your gateway.
Step 4: Installation and configuration of TOR
Picture of Installation and configuration of TOR
This one's quite easy:
sudo apt-get install tor
If you're connected to the Internet a download will be started, this takes some time.....
Now we need to edit the TOR configuration file . You can find it here: /etc/tor/torrc. Open this file with your favourite text editor an add/change these settings:
SocksPort 0
Log notice file /var/log/tor/notices.log
RunAsDaemon 1
ORPort 9001
DirPort 9030
ExitPolicy reject *:*
Nickname xxx (you can chose whatever you like)
RelayBandwidthRate 100 KB  # Throttle traffic to 100KB/s (800Kbps)
RelayBandwidthBurst 200 KB # But allow bursts up to 200KB/s (1600Kbps)
Step 5: Problems with the firewall
Picture of Problems with the firewall
If your Raspberry sits behind a firewall, you'll have to configure its settings. To allow other nodes in the TOR network to contact your TOR relay, you have to open the ports 9030 and 9001. 9030 is needed for the directory service and 9001 for relay operation. Please refer to your firewll manual, there are to many to explain how to do it for every single firewall.
Step 6: Start the TOR Server
After changing the settings you have to restart TOR. Open a terminal and type:
sudo /etc/init.d/tor restart
TOR is now restarted. Now we have a look at the log file (less /var/log/tor/log). If everything is fine, you'll find an entry like
Oct 18 22:59:21.104 [notice] Tor has successfully opened a circuit. Looks like client functionality is working.
at the end.
Congratulations! Now you have a TOR relay!
Step 7: Configuring your browser to use Tor
Picture of Configuring your browser to use Tor
To use Tor, you need a Tor client, which routes all your Internet traffic through the Tor network. To make you "invisible", the traffic travels through several randomly selected relays (run by volunteers like you and your Raspberry), before exiting the Tor network and arriving at your destination. This prevents your Internet service provider and people monitoring your local network from viewing the websites you access. It also prevents the websites themselves from knowing your physical location or IP address – they’ll see the IP address and location of the exit node instead. Even the relays don’t know who requested the traffic they’re passing along. All traffic within the Tor network is encrypted.
The first picture shows you how it works
An example: Let’s say you access instructables.com through Tor. Your Internet service provider and local network operator can’t see that you’re accessing this site – they just see encrypted Tor traffic. The Tor relays pass your traffic along until it eventually reaches an exit node. The exit node talks to instructables.com for you – from the perspective of this site, the exit node is accessing their website. (Of course, traffic can be monitored at the exit node if you’re accessing an unencrypted website.) The exit node passes the traffic back along the relays, and the relays don’t know where it ends up.
This makes it possible for Tor to offer anonymity and a path through Internet censorship and monitoring – people living under repressive regimes with censored Internet connections can use Tor to access the wider Internet without fear of reprisal. Whistleblowers can use Tor to leak information without their traffic being monitored and logged.
All this nice features have their price. Browsing with Tor makes it really slower. So you might now be able to see youtube videos, that are blocked in your country, but it may take some time until the video loads.
So how can you get this client and install it?
This depends on your operating system and browser. There are many good tutorials out there for almost every possible combination. You can find many other good (video) tutorials out there, but i think the following links should give you enough information for your first steps:
Windows: https://www.torproject.org/docs/tor-doc-windows.html.en
Linux/Unix/BSD: https://www.torproject.org/docs/tor-doc-unix.html.en
Debian/Ubuntu: https://www.torproject.org/docs/debian.html.en
Mac OSX: https://www.torproject.org/docs/tor-doc-osx.html.en
and last but not least:
Android: https://www.torproject.org/docs/android.html.en
Last words:
Remember not to provide any personal information – say, by logging into an account associated with you – while using the Tor browser, or you’ll lose the anonymity.
gar3742 months ago
Nice tutorial - I'd never heard of Tor until tonight when a mate posted on FB about it. Now configured and running. Thanks
n0m made it!3 months ago
Sweet, works smoothly :)
cambaio9 months ago
Alternative tutorial in http://unsuspectingbit.com/tutorial-private-anonymizing-proxy-raspberry-pi-tor-based/
squishyjoss11 months ago
Its excellent :)
meyotch1 year ago
I've got a quick question for anyone here who is more conversant with the Tor algorithm. And please point me to resources if there's a project like I describe already in motion somewhere else!
How well will a relay - of any type - function with an intermittent connection?
The scenario I'm imagining is a Tor relay mounted on a vehicle (car or bike) using a wireless connection. If one travels routinely through a crowded wifi environment in stop-and-go conditions, would such a relay be able to negotiate a connection and spend a useful amount of time serving as a relay? Such as while stopped at a light or crawling along in congestion? Or while your bike is parked outside a place with an open network.
I understand some of this might violate TOS for some networks, but be assured, this is just a thought experiment. I have too many other hobbies right now.
amazing
Piney1 year ago
You forgot
Then add this line to your /etc/apt/sources.list file:
deb http://deb.torproject.org/torproject.org wheezy main
Then add the gpg key used to sign the packages by running the following commands at your command prompt:
gpg --keyserver keys.gnupg.net --recv 886DDD89
gpg --export A3C4F0F979CAA22CDBA8F512EE8CBC9E886DDD89 | sudo apt-key add -
Now refresh your sources, running the following command (as root) at your command prompt:
apt-get update
If there are no errors you're good to continue.
We provide a Debian package to help you keep our signing key current. It is recommended you use it. Install it using
apt-get install deb.torproject.org-keyring
To finally install Tor just run:
apt-get install tor
tor rocks
Ak1r41 year ago
Hi there, thx for the nice how to.
i've got two question about the follwing part:
"Add the line
tor ALL=(ALL) ALL"
i quess this is for the rights the tor user will get. is it ok to give him all? oder am i on the wrong way. i just wanted to know if this influences my normal pi user.
and there ist also the second question if i could run this tor -relay while im logged on with the pi user but start it in terminal with the tor user. or is this a stupid idea?
thx a lot
nice description of tor, how widely is tor being used, how much data passes through any given tor node per day? per hour?
Michael_oz1 year ago
Nice and straight forward.
Perhaps you could add a brief step at the end on how to use TOR?
fNX (author)  Michael_oz1 year ago
Thank you! I've added a step at the end with information how the client works and how to install it.
