Raspberry Pi Touchscreen Setup
11,973
149
Published
Introduction: Raspberry Pi Touchscreen Setup
For this project you will need the following components:
Raspberry Pi 3
Raspberry Pi 7" Touchscreen Display
Package includes:
  • DSI Ribbon cable
  • 4 x Jumper wires
  • 4 x Screws (used to mount Pi board to the Adapter board)
Touchscreen Display Enclosure
Step 1: Setting Up the Touchscreen.
Flip over the screen and you will find the Adapter board already attached to the back of the screen.
Open the ribbon housing by slightly sliding out the black brackets on either side of the housing at the same time. (May need to use fingernails.)
Insert the DSI Ribbon blue side down.
Step 2: Connect Jumper Wires.
The kit includes 4 jumper wires. Insert the wires into pins correct pins on the board.
(You can use different colors than what I chose, however the color will need to match up with the correct pin on the Pi board in later steps.)
  • GND (Black)
  • 5V (Red)
  • SCL (Yellow)
  • SDA (Green)
Step 3: Install a Keyboard to Your Pi.
Before attaching the Pi to the Adapter board you will need to configure it for touchscreen use.
Hook up your Pi to a keyboard and monitor.
Open Terminal and type:
sudo apt-get install matchbox-keyboard
Reboot your pi:
sudo shutdown -r now
The keyboard can be found by clicking the Menu -> Accessories-> Keyboard.
If you do not see the Keyboard in the Accessories menu after reboot, or if you would like to make a Desktop icon,
Open Terminal:
cd Desktop
nano keyboard.sh
This opens GNU nano:
#!/bin/bash
matchbox-keyboard
In Terminal: (Command that makes the shortcut icon executable.)
chmod +x keyboard.sh
Step 4: Adjust Screen for Rotation.
When I first tested the touchscreen in the display case, it appeared upside down.
Follow these steps to flip the screen.
In Terminal:
sudo nano /boot/config.txt
Add line:
lcd_rotate=2
To exit:
Ctrl + X
Y
Enter
Shutdown Pi and remove all plug-ins.
Step 5: Mount Pi to the Adapter Board.
Now you are ready to attach the Pi.
Align the Pi so the ribbon ports are stacked on the same side.
Secure the boards together with the 4 screws included.
Slide the ribbon brackets upward on the Pi to open the housing.
Insert the ribbon and slide the ribbon brackets back down to tighten.
Attach wires to the Pi board.
  • GND (Black) to the third pin down on the right hand side,
  • 5V (Red) to the second pin down on the right,
  • SCL (Yellow) to the third pin down on the left hand side,
  • SDA (Green) to the second pin down on the left hand side.
Step 6: Enclosure Assembly
  1. Lay white frame face down onto back of screen.
  2. Align the back of the enclosure with the correct openings for the Pi board.
  3. Secure together with the 4 screws included.
Step 7: Power Up!
Plug in your mini USB to a power outlet or an external battery pack.
Voila! Your touchscreen is ready.
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    i have followed all you instructions but the screen will not come on . i have power to the board but nothing to the screen
    3 Comments
    Thanks for this. I made a different version of this and the upside down screen was driving me nuts. I'm going to cobble this into my car. Kudos!
    You are welcome! Glad to hear it works.
