Raspberry Pi Web GPIO With Live Streaming
Published
Introduction: Raspberry Pi Web GPIO With Live Streaming
About: We are a team of IoT & Embedded Systems developers. We are working in Raspberry Pi and Arduino.
In this project I'm going to tell you about how we can get the gpio pin Button and live streaming from our raspberry pi camera in a single web page so we can control our appliances from anywhere by simply clicking the button on a web page. And also we can able to see that in our live steaming.
Step 1: Software Used
a) Raspbian OS: This is the recommended os for raspberry pi. You can also installed other OS from third party. Raspbian OS is debian based OS. We can install it from noobs installer. you can Download here
b) Python idle: This is the software we get in raspbian os. For this project we have used python script.
c) Putty: we are using putty for remote access of Raspberry Pi.you can Download here
d) Win32DiskImager: This software is used to burn Raspbian Os on SD Card. you can Download here
e) SDFormatter: This software is used to format memory card. you can Download here
Step 2: Hardware Used
1) Raspberry Pi
2) Raspberry Pi Camera
3) Power Supply
Raspberry Pi: This is the latest version of raspberry pi. In this we have inbuilt Bluetooth and wi-fi, unlike previously we have to use Wi-Fi dongle in one of its usb port. There are total 40 pins in RPI3. Of the 40 pins, 26 are GPIO pins and the others are power or ground pins (plus two ID EEPROM pins.) There are 4 USB Port and 1 Ethernet slot, one HDMI port, 1 audio output port and 1 micro usb port and also many other things you can see the diagram on right side. And also we have one micro sd card slot wherein we have to installed the recommended Operating system on micro sd card. There are two ways to interact with your raspberry pi. Either you can interact directly through HDMI port by connecting HDMI to VGA cable, and keyboard and mouse or else you can interact from any system through SSH.
2. Raspberry Pi Camera: The Raspberry Pi camera module can be used to take high-definition video, as well as stills photographs. It’s easy to use for beginners, but has plenty to offer advanced users if you’re looking to expand your knowledge. There are lots of examples online of people using it for time-lapse, slow-motion and other video cleverness. You can also use the libraries we bundle with the camera to create effects.
Step 3: Working Principle
First you need to update and upgrade your raspberry pi in latest version
So for that you need to run these two commands in your raspberry pi Linux terminal
sudo apt-get update
sudo apt-get upgrade
Now you will have to install apache and php on your system
So for that run these commands below
sudo apt-get install apache2 -y
sudo apt-get install php5 libapache2-mod-php5 -y
After successful installation of all these things now you need to clone one repository in your terminal and that repository is WiringPi
So install that by giving these commands
git clone https://github.com/WiringPi/WiringPi
cd WiringPi
./build
Now for getting the live streaming from your pi camera you need to clone one repository from github
git clone https://github.com/DeligenceTechnologies/Raspberr...
Now after cloning this just give these commands
cd Raspberry-pi-based-HD-surveillance-camera/
chmod u+x RPi_Cam_Web_Interface_Installer.sh
./RPi_Cam_Web_Interface_Installer.sh
So when you will successfully execute these commands. go to any browser and type the IP of your raspberry pi and hit enter you can able to see the live streaming of your raspberry pi
Here you go now you need to clone one more repository to get the GPIO pin button of your raspberry pi in that page along with live streaming
So here is the command
git clone https://github.com/DeligenceTechnologies/RPi-web-...
Now copy the content of this repository on the same location where your camera streaming files are there i.e. /var/www/html
sudo cp -R RPi-web-gpio-with-live-streaming/* /var/www/html
After that go to your browser and type IP of your pi
so you will get the web page where on the left you will get the GPIO Buttons and on the right you can able to see the live streaming as you can see in the above image
Step 4: Video
Here you can see the video of the project
Congratulations you have successfully finished your project
If you have any doubt regarding this project feel free to comment us below or you can mail us on info@deligence.com. And if you want to learn more about these type of project then feel free to visit our youtube channel
Thanks & Regards,
Deligence Technologies
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
