Introduction: Raspberry Pi Zero - Control RGB Leds With E-Waste
Hey Thrifty Nation,
I’m going to show you how to control an RGB led strip with your raspberry pi and pigpio
I built this circuit out of e-waste consisting of an old motherboard and a dead power supply
If the video above is not working for you, try the link below
https://youtu.be/3y_YuqfOyIA
Step 1: ​These Are the Parts We Need for This Project:
Picture of ​These Are the Parts We Need for This Project:
These are the parts we need for this project:
  • breadboard
  • 3 mosfets (from the motherboard)
  • wire (from the psu)
  • p4 connector (from the motherboard)
  • p4 connector & wire (from the psu)
  • 12v power source (1a or higher rating, i used an old laptop power brick)
  • RGB Led Strip
Step 2: Tools You Will Need
Picture of Tools You Will Need
all you need are a few tools and a bit of time
you will need:
Step 3: Lets Take a Look at the Led Strip.
Picture of Lets Take a Look at the Led Strip.
I won’t go into how to desolder components in this video but once you have your components,
lets take a look at the led strip.
these led strips have 4 wires, one of them is 12v power and the other 3 are Red - Green and Blue
With your raspberry pi you can control the RGB lines through Pulse Width Modulation to change the brightness and color of your led strip
Step 4: Lets Build the Circuit
Picture of Lets Build the Circuit
Start by placing your a mosfet into the breadboard like so
Step 5: Build Your Circuit
Picture of Build Your Circuit
using a jumper wire; connect the source pin to the ground bus of your breadboard
then connect a wire between one of your rgb pads on the strip to the drain pin of the mosfet
use a jumper wire to connect to the gate pin of the mosfet and set the other end aside
Step 6: Replicate
Picture of Replicate
Now that we have one complete, go ahead and replicate the same for the other two colors
Step 7: Wire to Gpio
Picture of Wire to Gpio
Now connect the wires from the gate pins of the mosfets to the gpio pins on your raspberry pi (I used 17 for red 22 for green and 24 for blue)
Step 8: Common Ground
Picture of Common Ground
Now lets give your new circuit and the raspberry pi a common ground, using a jumper wire; connect the ground bus of your breadboard to a ground pin on your raspberry pi
Step 9: Power Hookups
Picture of Power Hookups
finally, plug your positive and negative leads of your 12v power supply to the positive and negative bus on your breadboard and also the 12v power from the led strip
Step 10: Software
Picture of Software
install the pigpio library at http://abyz.co.uk/rpi/pigpio/
and start it with this command sudo pigpiod
RGB colors are comprised of 3 segment numbers each ranging from 0-255
The range equals brightness of each of the 3 colors allowing you to mix and match to arrive at your chosen color. Now its easy with a bit of Python to control the leds with these commands in your terminal:
pigs p 17 255 - The red part will be set up to 100% and the LED's should be red
pigs p 22 128 - The green part will be set up to 50% and the LED's should be yellow
pigs p 24 128 - The blue part will be set up to 50% and the LED's should be purple
Step 11: Done!
Now go out and have some fun, I’d love to see what projects you create with this!
If you are looking for more fun projects to do with your raspberry pi, check out this video above
Looking for more?
Here are some items from my workbench
Tenma Temperature Controlled Soldering Iron
Breadboard w/jumper wires
Power Supply 12v
Check out www.thethriftyworkshop.com
ibaltimore (author)2017-07-14
Do you think it would be easy to connect an audio/mic input and have the LEDs controlled by sound frequency (Red for bass, Green for middle, Blue for Treble)? That would look amazing on my DJ rig.
Kranzy (author)2016-09-05
I am looking at doing a similar thing...however I want to replace a controller I currently have that is driving 2 sets of led lights. Currently it goes from a controller to 2 separate amplifiers which is driving the 2 sets of lights. Is it possible to run from the pi gpio pins direct to the rgb amplifers without running it through mosfets as there should be minimal load on the pi as its not driving the lights?
JesusG33k (author)2016-02-13
I might add a Pi inside my PC case and have it run some lights of the PSU. Thanks for sharing!
A little sneak peek on what I am working on next,
I salvaged a scroll wheel from an old mouse that died, it is called a rotary encoder. With this I hope to be able to utilize it with the gpio on the pi and add a bit of code to change colors with the rotary encoder !
thriftyworkshop (author)2016-02-19
If anyone has questions let me know, i'll answer as quickly as possible.
thriftyworkshop (author)2016-02-11
Right now it's still sitting on my desk same configuration but I have a new video in store that will show the application :)
About This Instructable
11,540views
87favorites
License:
More by thriftyworkshop:Add Passive Cooling To The Raspberry Pi 3Solder Header Pins to a 1602A LCD With a BreadboardSolder Gpio Headers to a Raspberry Pi Zero With a Breadboard
Add instructable to:
