Introduction: Raspberry Pi Zero + Repetier Server
Picture of Raspberry Pi Zero + Repetier Server
If you managed to get a pi zero then you have noticed it is crazy tiny and it works well for low-er use CPU programs, one of which is Repetier-Server. Repetier Server is a bridge between you Repetier-Firmware controlled 3D Printer and your web-browser. The setup is easy, you will need the fallowing to get started:
1) Raspberry Pi Zero
2) OTG USB HUB or OTG adapter and USB HUB
3) Power cable
4) usb ethernet or wifi adapter
5) SD card with raspbian image
Step 1: Open Putty (or Any Other SSH Client) and Connect to Your Pi
Picture of Open Putty (or Any Other SSH Client) and Connect to Your Pi
Enter the fallowing commands to install the server:
1) wget http://download.repetier.com/files/server/debian-a... -O repetier_armel.deb
2) sudo dpkg -i repetier_armel.deb
3) sudo service RepetierServer start
its done!
Step 2: Open Server and Your Done!
Picture of Open Server and Your Done!
the server address will be by default '[ipaddress]:3344'
RodriMendoza made it! (author)2017-06-02
It is weird to me that this simple set of instructions are not available on repetier's page, or at least i could not find it. Just the SD image. It is a bummer if you would want to use a Pi 3 that you have already configured and handling other projects. Great tutorial! Works beautifully.
JonathanL91 (author)2016-10-30
i keep getting this error
pi@raspberrypi:~ $ sudo dpkg -i repetier_armel.deb
dpkg-deb: error: `repetier_armel.deb' is not a debian format archive
dpkg: error processing archive repetier_armel.deb (--install):
subprocess dpkg-deb --control returned error exit status 2
Errors were encountered while processing:
RobertS319 (author)JonathanL912016-11-12
The command in part 1 is not showing the complete link. try
" wget http://download.repetier.com/files/server/debian-armel/Repetier-Server-0.75.1-Linux.deb -O repetier_armel.deb"
and then start part 2 and 3 again
About This Instructable
4,828views
26favorites
License:
Bio: I like to create new things! I'm very interested in IOT and just Internet Stuff. I am not responsible for any injury or deaths ... More »
More by Funguypro:3D Print Your House!!!!!DIY Raspberry Pi Indoor Outdoor WebcamSee Through Buildings With a Drone
Add instructable to:
