Raspberry Pi Zero Switch Off by Button
8,544
79
Posted in TechnologyRaspberry-pi
Introduction: Raspberry Pi Zero Switch Off by Button
I've a small and sweet Raspberry Pi zero . When I switch on my Raspy zero without a monitor or keyboard or LAN, I don't want switch off the pi directly by putting off the socket by the line. In fact this action can compromise the Raspy. You can be breaking the kernel, and the system can crash after that.
I've written a code that put the last pin in standby for a connection between the ground. When I connect the last pin with the ground, the code starts. The code is a simple sudo shutdown -h now
Buy your Raspberry Pi zero on Amazon
Step 1: Create the Code
Go to GitHub and read the code (https://github.com/masteruan/Raspbery_switch).
import RPi.GPIO as GPIO
import time import os
buttonPin = 21
GPIO.setmode(GPIO.BCM)
GPIO.setup(buttonPin, GPIO.IN, pull_up_down=GPIO.PUD_UP)
last_state = True
input_state = True
while True:
input_state = GPIO.input(buttonPin)
if (not input_state): print("Shutdown")
os.system('sudo shutdown -h now')
time.sleep(0.05)
GPIO.cleanup()
Step 2: Connect the Pins
Now is the moment to connect the pin. After the starting of Raspberry Pi, you can connect the last pin to ground.
You can read on screen, the command: sudo shudown-h now and the Raspberry Pi switch off.
Materials
Buy a switch on Amazon
Buy a tilt switch on Amazon
Step 3: Modify the Rc.local
Now if you want start automatically the script do you modify the rc.local file. This file start when you switch on the Raspberry Pi
#!/bin/sh -e
# # rc.local # # This script is executed at the end of each multiuser runlevel. # Make sure that the script will "exit 0" on success or any other # value on error. # # In order to enable or disable this script just change the execution # bits. # # By default this script does nothing.
# Print the IP address _IP=$(hostname -I) || true if [ "$_IP" ]; then printf "My IP address is %s\n" "$_IP" fi
python /home/pi/Desktop/shutdown.py &
exit 0
Step 4: Mounting a Switch Or...
Now you can mount a switch like in photo. I've mounted a tilt switch. When I turn upside down the Raspberry Pi, this switch off.
  • Make it Move Contest
  • Woodworking Contest
    Woodworking Contest
  • Casting Contest
    Casting Contest
1 Questions
Where to get a switch like this and if I want headers to plug into, where to get them?
Hi,
see the link in the description.
2 Comments
Python has some problems with Indentation.
This code works for me:
import time
import os
buttonPin = 21
last_state = True
input_state = True
while True:
print("Shutdown")
time.sleep(0.05)
GPIO.cleanup()
Yes you are right! Follow this: https://github.com/masteruan/Raspbery_switch
