Raspberry Pi As Webserver.
126,398
360
18
Posted
Introduction: Raspberry Pi As Webserver.
This instructable will only briefly show a way to enable webtraffic to your Raspberry Pi.
In the last step you'll find a guide to add the content.
You'll need:
1 Raspberry Pi
1 Router
1 Micro USB cable
1 Ethernet cable
(and of course an Internet connection)
Step 1: Raspberry Pi As Webserver - Connect to Router.
First you need to connect your Raspberry to your router.
Connect ethernet cable to a free Lan-port. (See picture above).
Connect Micro USB to router or if you have different cable, to your power net.
I'm also using a USB-hub and discstorage...
Step 2: Raspberry Pi As Webserver - Configure Router.
To enable access to your Raspberry Pi you need to enable traffic to it.
Steps:
1. Log in to your router.
2. Check current ip.
Under Attached devices check your current ipaddress for your Pi.
3.Lock current ip to your Raspberry Pi.
Under LAN-setup Add an address reservation for your Pi.
4. Configure asDMZ-machine.
Under WAN-setup Enter current ip and enable as Default DMZ Server.
Step 3: Raspberry Pi As Webserver - Setup Webserver.
Now you'll need to add content to your webserver.
Here you can find a guide to setup and add content to your Raspberry Pi webserver:
https://www.instructables.com/id/Install-a-webserver-on-Raspberry-Pi/
If you are looking for a guide to use ssh to talk to your Pi, look here:
https://www.instructables.com/id/Use-ssh-to-talk-with-your-Raspberry-Pi/
My Raspberry Webserver can found here:
http://213.65.123.101/qr - a QR Business Card generator.
http://213.65.123.101/whoiam/ - all you want to know about what google knows about you.
Here you can find a guide on how you can use your QR business card:
https://www.instructables.com/id/Digital-business-card-in-your-iPhone-smartphone/
Good luck, and may the Pi be with you!
    • Space Challenge
      Space Challenge
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    18 Comments
    Wow, thanks for the help!
    This is to allow a setup with pi and a standard router and be able to create a standalone webserver?
    Yes Port5, your pi should be accessible from the internet if you follow the instruction. Did you succeed?
    Första svensken jag sett på Instructables! :D
    First sweed I've seen on Instructables! :D
    Medlem sedan Feb 27, 2009!
    Gott Nytt År!
    Haha!
    Veteran alltså! ;)
    Gott nytt år på dig med!
    Yay! it works and stuff,
    Can I use this to upload and download files?
    Sure, it is small, but it is a server. If you only need to upload and dowload files, perhaps you are looking for a NAS ? But a Raspberry Pi is much more fun! ;)
    I like the simplicity of this instructable compared to others about setting up a server on the raspberry pi. It does not involve Mysql or other stuff i have no idea how to do yet. I am still waiting for my raspberry pi, probably getting one for christmas. Also ablut a raspberry pi laptop, check out this ible' https://www.instructables.com/id/LapPi-A-Raspberry-Pi-Netbook/
    Don't really need MySql for a webserver, but if you want to present anything more than just stationary html pages, MySQL comes in handy.
    Should really give it a try :-) It is really not that bad.
