Introduction: Raspberry Pi Simple Blog Server.
Note: you need to have at least some knowledge of the linux command line to complete this instructable. Using putty or ssh from a gui environment to log into the RPi is extremely helpful. Makes it easy to just copy and paste commands.
Note 2: You could actually install this on most any computer system with the Apache2 php requirements fulfilled.
Step 1: Name Change to Protect the Innocent.
You will want to change the name of your Raspberry Pi or you might get another server from the web. Also I am sure you have already set up your router to set the raspberry pi address. See your router manual on how to do that.
$ sudo hostname
Add oeraspberrypi to the list.
Use ifconfig to get your ipaddress of the RPi
$ ifconfig
eth0 Link encap:Ethernet HWaddr xx:xx:xx:xx:xx:xx
inet addr:192.169.1.41 Bcast:192.168.1.255 Mask:255.255.255.0 < < < < <
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:60188 errors:0 dropped:0 overruns:0 frame:0
TX packets:32615 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:80088549 (76.3 MiB) TX bytes:3105057 (2.9 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:32 errors:0 dropped:0 overruns:0 frame:0
TX packets:32 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:2540 (2.4 KiB) TX bytes:2540 (2.4 KiB)
Then you will need to edit your host file to reflect that address.
Step 2: Web Server Software Setup.
There are two basic programs we want to install. Apache2 the web server and PHP a programming language for use with the server.
$ sudo apt-get install apache2 php5 libapache2-mod-php5 php5-cli
That will take a little while to install. Be patient.
Then you need to do a fix for the server.
$ sudo nano /etc/apache2/conf.d/name
For example set add ServerName localhost or any other name:
or you could use
Servername yourservername
Save the file and restart Apache 2
$ sudo service apache2 restart
Test the server:
Point a browser to the RPi You should get the setup page.
Now we need to test the PHP install..
$ cd /var/www
You should already see index.html with the code that shows you the home page.
Now we need to create a new page
$ sudo nano phpinfo.php
<see picture>
Save and exit. Now point your browser to yourhostname/phpinfo.php
You should get the PHP status page.
Now you should be ready to roll.
Note: you may need to edit /etc/apache2/apache2.conf and add:
# add php useage
AddHandler application/x-httpd-php .html
Step 3: Get the Software.
Then you need to get the software to your Rpi. For MSWwindows you can use WinSCP, not a MSWindows user so you will have to look at it's instructions.
On linux Send the file to your pi home directory
$ cd downloads
$ scp flatpress-1.0-solenne.tar.bz2 oerapberrypi:~/.
or scp flatpress-1.0-solenne.tar.bz2 pi@oerapberrypi:~/.
Log into the Raspberry pi Go to your home directory to make sure the file is there: (ssh@rpiservername)
$ ssh pi@oeraspeberrypi
$ ls
Desktop flatpress-1.0-solenne.tar.bz2 helloworld.py hw hw.c python_games
Step 4: Software Install.
$ tar xvjf flatpress-1.0-solenne.tar.bz2
if you do ls you should see the Flatpress directory now. On linux Apache to has a special place where all the web pages are stored. If we were only going to run one web program, you could store the files in /var/www. I prefer to to use the whole directory on it's own. So lets move it.
$ sudo mv flatpress /var/www
You should see it now with the two other files we created in another instructable.
To the final step.
$ ls
flatpress index.html index.php
if you cd flatpress, you will see lots of files. but you really do not need to do that.
Step 5: Installing Flatpress.
$ cd /var/www
$ sudo chown -R www-data:www-data flatpress
$ sudo chmod -R 755 flatpress
Now you point your browser to servername/flatpress and just follow the instructions.
Step 6: Access for the World.
Port forwarding see:
https://www.instructables.com/id/Your-personal-intranet-Part-1/
https://www.instructables.com/id/Your-personal-intranet-Part-2/
DDNS on DD-WRT:
http://www.dd-wrt.com/wiki/index.php/DDNS_-_How_to_setup_Custom_DDNS_settings_using_embedded_inadyn_-_HOWTO
Step 7: Other Part of a Lamp.
Because there has been so much consternation of using MySQL now that it is in the hands of Oracle, prefered a web application that did not need it. Most people are now preferring MariaDB over MySQL.
