Raspberry PiFace L298N Bi-Directional DC Motor Control
Published
Introduction: Raspberry PiFace L298N Bi-Directional DC Motor Control
This instructable will show you how to wire up your raspberry PiFace to allow you to control the direction of a DC Motor.
Kit Needed:
1 x DC Motor
1 x Power for the motor (I've used a 9V Battery) and connecting leads
1 x Raspberry Pi
1 x PiFace
1 x L298N Motor Driver Board (Can be purchased from eBay)
Selection of Jumper Leads/Wire depending on exactly what kit you have.
Step 1: Connecting the L289N to the PiFace
This is the bit I found the trickiest to work out however now I've got it working it seems obvious.
First connect the +5V on the L289N to the 5V on the PiFace.
Now connect the 0V on the PiFace and the negative lead from your battery/power supply to the 'power GND' on the L289N.
Connect the positive lead from your battery/power supply to the +12V on the L289N.
Connect your DC motor to one of the outputs, it doesn't matter which terminal you connect each wire to.
Put a jumper on the enable pins for the output you are using or just wire them together.
Connect the 2 input pins next to the output you are using to outputs 0 & 1 on your PiFace
You are now all connected up and ready to make your motor move!
Step 2: Make Your Motor Move!
To quickly test that this works turn output 0 on (using the emulator), this should cause the motor to spin. Turning off output 0 and turning on output 1 will make the motor spin the other way.
If you wanted you could now write some python code to control your motor, I've written this as I Cannot find a single other guide that covers L289N use with PiFace so hopefully you will find this helpful.
    • Clocks Contest
      Clocks Contest
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    Hi, thanks for your tutorial which is very nice..
    I'm interested to have the python code to handle the device.
    Can you be so kind to tell me where can I find this?
    Thanks again.
    Arnaldo
