Raspberry Pi Print Server
Published
Introduction: Raspberry Pi Print Server
About: Printer + Sofa = ??????
A print server that tastes of pi. This project assumes that you have the latest version of raspbian (which can be downloaded at) https://www.raspberrypi.org/downloads/raspbian/. And an active internet connection.
(When imaging the SD card be careful to select the right device otherwise BOOM! There goes your shopping list and the 4086 page novel you were working on)
Let’s get started!
Step 1: Updates!
Turn on your pi and login to the GUI. Next go to LX Terminal and type
sudo apt-get update
That’s it for this step.
Step 2: Auto Login
This no longer works in Rasbian Jessie. See: https://raspberrypi.stackexchange.com/a/49399for how to do this.
Do you really need to log into your pi every time you turn your print server on? No! So in Lx terminal type:
sudo nano /etc/inittab
Then go to the following line in the file
1:2345:respawn:/sbin/getty 115200 tty1
Put a # before the line. It should look like this
#1:2345:respawn:/sbin/getty 115200 tty1
Then below it type
1:2345:respawn:/bin/login -f pi tty1 /dev/tty1 2>&1
Press crtl+x then press y to save the file
Step 3: Installing CUPS
CUPS is the print server software required to instruct the printer to print. So to install it type
Sudo apt-get install cups
Into LX Terminal
That was easy!
Step 4: Configure CUPS
Ok so CUPS has been installed but now you need to configure it
To configure CUPS type:
*02/03/17 eyesofnova found an error. Correct code is:
sudo usermod –aG lpadmin pi
Step 5: Plug in Your Printer
Now is the time to shut down your pi and plug in the printer and move it to an ideal location. I’m using the brother HL-1030 which has a parallel port. To use a printer with a parallel port use a USB to parallel wire.
Step 6: Turn It On
This is as simple as plugging it in.
Step 7: Adding a Printer
Go to youripaddress:631 and press add a printer. If prompted for login information the username is pi and the password is raspberry. Now fill out the form. Select your Printer, Printer name, Printer Driver and printer description. Then press save and exit the browser.
Step 8: Try It Out
Add the printer as you would add a network printer. And print a test page.
Well done! Have a coffee and relax.
Please do vote for me in the contest
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    8 Comments
    Fantastic instructable, I have now recovered much needed desk space and can now print from all our computers in my home. 10/10.
    Great! My printer still is the size of my house, so won't fit on my desk!
    Hi! When i get in to the second step.. the file is empty... when i type
    "sudo nano /etc/inittab" i only get an empty nano frame... do i something wrong...?
    Just a heads up for the usermod line. You need to run it as sudo and you need to make sure usermod is lowercase
    You just have to go through your code again just to make sure it is all correct
