READ ME FIRST!!!!!!!!!!!!!!!!!!!!!!
3/1/10
I just reorder some new parts to fix some of the problems that i have. Please don't try to work on this till I am finish solving some of the issues (Unless you are a Level 10 Electrical Engineer.)
4/4/10
Well i figure out why this doesn't work as well. LED need a certain amount of milliamps to turn on. The current that comes out of the headphone jack is WAY TO LOW. It bearly turn on the leds (so you can only see it while it is dark and the volume is MAX OUT).
So i guess i would need to make a amp before the connecting it into the transistor.
Also if you want to use the microphone you will need a PRE-amp.
If you have a case window just like I do you sometimes wish you could turn off all those lights. I was like one those guys, but I added this other feature call the "RAVING MOD".
This mod will show explain how to make your LEDs to turn off and on with the sound of your music (or games or anything that comes out of your audio out). You will also learn how to COMPLETELY TURN OFF ALL YOUR LIGHTS.
Disclaimer 1: My Grammar is AWFUL. So if you can help clarify something please go ahead and tell me.
Disclaimer 2: I am not responsible for anything that happens to you or your computer. I am a ME not a EE.
Disclaimer 3: Never open your Power Supply. I needed Fans to mod so I did and I learn my lesson.
Disclaimer 4:Before I continue I just want to say that the circuit for this instrubable did not just came to me one day. A fellow student in my school gave me the idea that a NPN Transistor will make the lights turn On and Off.
Materials
Computer Fan (Any size or type and no Leds are needed)
26 gauge wire (Black and some other color)
18 gauge wire (Black and some other color)
Zip Tie
Male and Female 4-pin molex
Male and Female pin molex
NPN transistor
Female Audio connector
2x Two way or 1x Three way switch
Audio Splitter
Male to Male 3.5mm audio cable
Or Microphone with 3.5mm male cable (needs Mic Preamp)
Tools
Wire Cutters
Wire Strippers
Small Standard Screwdriver or something similar
Glue Gun and Glue Sticks
Electric Tape
Soldering Iron and Solder
Brainz
Remove these ads by
Signing UpStep 1Analyzing the Fan
The first ways is by having the wire wrap around the fan. This will probably happen if you don't have a fan that already had LEDs.
The second way is by a combination of wrapping around and going under the union bridge. The main reason why you will choice this option will be because of the canals in the bridge that could be to small for the wire that you may use. If the bridge doesn't have the canal you might need to use the "first way". Also there must be a hole and some space under that hole to fit a wire.
The third way is probably the rarest way to do it. The canal on the bridge must be big enough to fit two wires. If the 26 gauge wire is to big you might need to use a much smaller gauge for it to work.
My Warcraft character is a level 30 engineer- does this count?
Well, if you're an electrical engineer or an experienced hobbyist, give it a shot
http://www.instructables.com/id/LED-VU-meter-that-dances-to-computer-music/
On this one you can you the amp he did:
http://www.instructables.com/id/be-ZIGGY-STARDUST-gone-SPACE-VIKING-Volume-Indica/?ALLSTEPS
^_^
!_!
nuff said
nuff said =)
But thats just me.
Just Awesome
now...i have a question about one of my switches... it has three prongs, all labeled: Power, ACC, and Ground...this is going to be the first switch...which prongs do i connect the power to? btw...i got all of my supplies from radioshack if that helps...this is the switch...
http://www.radioshack.com/product/index.jsp?productId=3098835&numProdsPerPage=60&retainProdsInSession=1&y=13&x=10
