3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Razor Ripstik LED's
Razor Ripstik LED\
Here's a cool idea if you like to skate at night.
Step 1The Items
The Items
What you will need:
two 3v LED's
one on/off switch
two AAA battery holder's
A philips and a flat head type screw driver plus alan key
A Dremel or a Chisel.
You'll need drill and some wiring at about 4ft long should be enough. 14 to 18 gauge will do fine.
Cost: about $15 U.S.
Time: 1 hour and 20 minutes
14 comments
Nov 22, 2010. 1:28 AMvader406 says:
Now...how could we implement this on a ripstik air? ;)
Aug 31, 2010. 5:39 PMElectroinnovation says:
Cool. I made something like this but instead of using two LED's i used 20...just a little different ;)
Sep 3, 2010. 4:14 PMElectroinnovation says:
well its a little complex but if you know basic circuitry you could make it. I used 2 2AAA battery holders with a source selection switch (a kind of homade battery backup system) and then the main power source. So the source is 3v's and unfortunatly i thought the leds wer 3v also...but they werent...theyr 2.4. So i had to buy resistors :/ ahaha
Apr 3, 2010. 1:57 PMhellodcm says:
 Hey can you please post a picture of the whole board with the plates off and do you have a battery pack at the back and at the front near the torsion bar? Good instructable
Sep 7, 2009. 4:50 PMPie_eata says:
Sep 8, 2009. 5:27 PMPie_eata says:
i took off the face plates wired it up and used my dremel and a grinding drum to slowly borrow out a pit for the 9v deep enough so i could put the plates back on. and no i don't run Grip tape i just painted the panels.
Aug 7, 2009. 8:19 PMsarroopoo says:
Guide looks good, except for the schematics, you have both poles of the LED's going to positive, and you have the switch jumping the positive and the negative. For anyone not sure, you would want to connect positive to positive and negative to negative on the battery holders, run one wire from positive, and one to negative (a complete circuit) and put the switch in line, do not jump the line between polarities.
Feb 7, 2009. 8:12 AMPie_eata says:
I done this except i used a 9v and wired up a total of 8 flashing leds.
Aug 22, 2008. 5:37 PMboognishmofo says:
I just started a new job and one of the mechanics "claims" his brother was the one that invented these boards. He said he also invented gloves with bearings in them that you can use as skates. They are supposed to be cool in sewer drainage pipes. Hey, he could be right. I'm not callin him a liar.
Aug 19, 2008. 7:27 PMlilpunk1302 says:
That's really awesome, I might actually do this to my waveboard(When I finally get around to taking the deckplate off for no reason) Couple pointers though, 1. You don't mention soldering anywhere in the guide(I think, I'm half asleep atm) 2. I HIGHLY recommend using resistors on your LED's unless you plan on swapping em out as often as the batteries and 3. Don't buy electronic parts from Radio Shack, sure the stores are everywhere, but you can buy all the parts in higher quality from an independent component retailer for a third of the price(~$5 for everything if you have the Soldering iron, solder and chisel)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:randyfivesix
