Rc Twin Boom Plane ! Complet Build ! the Best Plane for Fpv and Aerial Video !!
Introduction: Rc Twin Boom Plane ! Complet Build ! the Best Plane for Fpv and Aerial Video !!
hi !! i would like to share with you the plane that i made , is a twin boom plane , very great plane :!!!
and great design. It can fly fast and aerobatically, slow and smooth, can carry weight like cameras and FPV gear and it looks unique in the air , so The twin boom configuration means the motor doesn't need to sit up high, so the fuselage can be slimmer.
i decide to do a complet video of the build , this is the video :!!!
Wingspan - 1.3m (53")
Length - 80cm (32")
i used polystyrène foam and coropast !!! this is the first time to use Coroplast and i find it so easy with the hot wire !
Airframe weight - 480g w/o electronic
ToTal weight ; 1009g with 2* 3s 1550mah = 3100 mah lot of power that mean a very long flight time !!!!
Motor - Turnigy D2836/8 1100kV ( you can use any motor that give you 600+ of thrust )
Hobbyking 30A ESC
Prop - 9*6,
all electronic from http://q.gs/DsIsI
Materials ;
polystyrène foam,
Hot glue,
double sided tape,
hot wire ,, and wood !!
and this is the fly test !
soon i will tested with gyroscope HOBBYEAGLE A3-L !!! and see what difference
so if you like this project
subscribe my channel to see more great project!!!
!!! hope to like it !!
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    Hi) Very amazing .Can you share with me about airfoil's dimension ? i havent any idea for airfoil .
