3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Re-Fill Printer Cartridge
Everyone has an inkjet printer, and everyone hates buying ink, because it is so dang expensive!
With this instructable, you can save about $100 every year!
(not to mention saving the environment)
Step 1The Tools/Supplies
The Tools/Supplies
A few tools are required..
Tools:
Drill
Small Drill Bit
Scissors
Syringe
Supplies:
Electrical/Duct tape
Ink Re-Fill kit
Empty Ink Cartridge
Paper Towels
(optional) gloves
24 comments
Jan 31, 2011. 4:32 PMnoglider says:
Where does one buy just the ink?
I'd like to know how to make the ink itself! Is this feasible?
Nov 24, 2011. 8:00 PMorrosta says:
Sure, you can make your own ink, and it can be cost effective. If you live in an area with abundant black walnut trees, many people will practically beg you to take the fruits out of their yard. You can boil the walnut husks for a nice brown ink and if you add some rusty iron into the mix (or simply boil it in a rusty old iron pot) you can get a very rich black ink. It is Archival too! I have made several gallons of it for the cost of a few burned logs and an hour or so of time.
Nov 18, 2010. 2:24 PMcoppeis says:
Where can I get a syringe?
Jan 4, 2010. 9:56 AMapp0 says:
 The modern ink cartridges are too smart, i wish this will work with my epson FX-800+ . but drilling may damage the cartridge, I'd better peel off the sticker, fill cartridge and put the sticker back
Jan 10, 2010. 10:43 PMmilsorgen says:
 Nothing ventured nothing gained my friend!
Oct 28, 2009. 9:06 AMtweekskratch says:
When I used to refill my #92 at Walgreens, they just shot (3) needles straight through the sticker. I'm not sure if they purged them, but never had any problems with ink distribution. If you have to purge it may be easier to drill... If not, through the sticker is way easier than drilling yet another hole in the side? plus Elec. tape residue gets all over not good if it gets on the print head... Don't forget to let them sit overnight so the ink has time to settle as this could also cause problems with the ink. Anyway, thanks for the technique!
Oct 5, 2009. 10:24 AMTurnip123 says:
Well, if you peel it off uniformly, fill the ink cartridge, and replace the sticker, everything is the same, AND you don't have unpredictable adhesive tape on the side of a printer cartridge (constantly moved), that is now clogged with drill fragments of ABS plastic. :D
Oct 5, 2009. 3:15 PMTurnip123 says:
Not on mine, but I have a 92 HP black cartridge.
Oct 4, 2009. 11:25 AMTurnip123 says:
You can also peel off the sticker...
Sep 25, 2009. 5:53 PMScroman says:
Some printer manufacturers are now making single use cartridges. After the ink is used up the printer wont use it again even after refilling. I know because I have a Lexmark Z2300 inkjet printer and tried to refill the cartridges and the printer still told me to change the cartridges and wont print.
Aug 16, 2009. 10:57 AMdjr6789 says:
i refill my ink cartridges with food colouring , its way cheaper
Apr 23, 2009. 8:44 AMjordand says:
Why don't you use the filling hold at the top of the cartridge, underneath the label
There is a very good Instructable on how to do this (they have the same cartridge as you) Here's the link http://www.instructables.com/id/Refill-your-Printer-Cartridge/
Apr 26, 2009. 9:21 AMjordand says:
Well tape it back up like you did to the massive hole you put in the side of your cartridge.
Apr 21, 2009. 9:38 PMpatsy0827 says:
Thank you! I wondered how this was actually done...I may try it myself one day....
Apr 20, 2009. 10:36 PMstuuf says:
Worst abuse of word processing software ever...
Apr 21, 2009. 9:12 AMstuuf says:
Just save your black box as a PNG image (or better yet SVG) and the file will be much smaller and you can print it directly from a browser.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:alex-sharetskiy
