3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Re-Tread your Slippery Pedals
Cycling in the rainy NW ,pedals without clips require Grip .  Heres a quick cheap (free) way
to give new traction to your old slick and slippery pedals before you slide off and crunch
your shin or 'you-know-what' =( .  It was just about to happen to me .
Step 1Dremel will Travel
Dremel will Travel
This could also be done with a hacksaw blade but a dremel is what I used .
It took all of 5 minutes .   This is my 1st ible so feel free to lay on the critiques .
8 comments
Nov 23, 2011. 5:32 PMmtaylor22 says:
I am not quite sure what you did, unless you just roughened up the "spikes".
I have some pedals about like that. I have been collecting little set screws and got a tap in the same size, hoping to just drill for traction pins and threadlock them in place.
The ones you show with screws for the plastic pedals may work, but you should saw-off the points or surely you will spike your shoes and maybe cut your leg really badly. Good luck.
Nov 26, 2011. 10:26 PMmtaylor22 says:
Thanks. It is not hard, but unless you can get a lot of the pins, threadlock, and a tap for a low enough price, it may be cheaper just to get replacement pedals such as Nashbar beartrap pedals. If you like running toe clips or SPD, you can get velcro "hipster" type toe straps with a large padded surface, instead of the old metal clips (ouch), for about $30. Great for sneaker rides.
Best bet is to find a bulk fastener dealer like Fastenal or mom-n-pop hardware store. You will need 8-16 set screws per pedal. Cheap nail polish works for threadlock on many non-critical things. Taps are about $2-5 each for small sizes that grub screws come in.
Nov 26, 2011. 10:33 PMmtaylor22 says:
After going to all the trouble to fix the traction problem, you can repack the bearings easily enough: drill small holes 1 per dust cap, and spray lithium grease in there with canned spray grease and the red tube. NOT wd40!
Jun 12, 2011. 1:27 PMvader9900 says:
I have a Boba Fett helmet, will it work in place of the Clone helmet?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:BtheBike
BtheBike
