3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Re-purposing an Air Wick Freshmatic Compact i-Motion
The Air Wick Freshmatic Compact i-Motion air freshener is an intriguing target for re-purposing. It uses a passive infrared (PIR) sensor to detect motion in a room and then increases the rate that it dispenses air freshener. This air freshener sells for $8, but you can sometimes get it cheaper with coupons.
Radio Shack carries the Parallax PIR module for $10. So the question is why bother re-purposing the Air Wick air freshener?
If you just want to replicate the Parallax PIR module, you can modify the air freshener by drilling 2 holes, adding a wire, and cutting a trace. Stopping here, you end up with a can of air freshener, 3 batteries, 2 slide and 1 push button switches, a cool aerosol valve, a medium power PNP transistor, a two wire connector with leads, and a LED.  I will show you two ways to do this; the simplest way, and a way to make the module the smallest.
However, If you want to go a bit farther, you can access the amplified analog sensor output as well as the digital signal, and have an externally accessible relay driver, and LED. I describe how all of these features are brought out to an easy to interface connector. You still end up with the air freshener, batteries, switches, and cool aerosol valve.
This last approach is a little more complicated.
Step 1Avoid the Competition
Make sure that you start with the right product. Glade also makes a motion detector air freshener. It uses considerably different technology.
The Air Wick air freshener uses a PIR sensor. The fragrance canister nozzle is depressed when it is inserted into the air freshener. The fragrance is dispensed by a valve in the air freshener that is activated by a relay driver type circuit. The PIR will detect large movements to about 15 feet with the Fresnel lens attached.
The Glade air freshener uses a light level (shadow) detector and a motor and gear train to depress the canister nozzle and dispense the fragrance. The motion detection on this product has much shorter range than the Air Wick air freshener. It generally sells for $5. It has a nice Sanyo motor that runs on 3 volts.
42 comments
1-40 of 42next »
Oct 16, 2011. 10:26 PMRobot Lover says:
Great hack! I personally would have just soldered the coil in a relay to the leads that would go to the motor. That way whenever someone walks by, it energizes the coil in the relay instead of the motor.
Sep 25, 2010. 8:42 AMskylen says:
I have to ask, Air Wick: What is the point of the "security screw" in this instance? I understand the use in public places to help impede theft/vandalism, but for an air freshner... really? Anyone who actually would be interested in re-purposing (hacking) the internals would laugh in the face of this silly fastener as an impedance to entry.
Sep 30, 2010. 2:56 PMiectyx3c says:
Good question. I thought about why they would put these TP3 tamper-proof screws throughout the gadget.
@ First idea was to prevent kids (ages 8-108) from tampering with it.
@ Then it might be to keep smarty-pants from repairing it so ya have to buy a new one.
@ But finally the true (!) reason hit me: it's a failed preemptive strike against I'ble makers from buying the unit for parts!
Nov 26, 2010. 10:59 PMRichardBronosky says:
#3 is TOTALLY TRUE. They often sell these kinds of things for a loss so that you will by the refills and they can make the real money. It's the same thing they do with razors and printers.
#2 is definitely not it. They don't want you to buy replacements units that they make no money on. They want you buying the refills that are very profitable.
Jun 17, 2011. 11:39 AMthines2 says:
Often the security type screws are used in robotic assembly type constuction, because the heads tend not to strip out, and the bits tend to last longer because of the larger surface area in contact with the fastener.
Oct 9, 2011. 10:31 PMDIY-Guy says:
I noticed after using square drive screws (for decking) that the star or "Torx" tip pattern almost never strips out. How do the triangle head screws compare to others? Can someone comment on the quality of the triangle head screws please?
Oct 9, 2011. 6:06 PMlferrier says:
This is a very useful hack as PIRs can be used for lots of things. I found it incredibly easy to do and use. Thanks so much.
Oct 9, 2011. 5:40 PMross_valusoft says:
I took the simple approach; just connected the led of a cheap optocoupler (CNY 17-3) in parallel with the Wick unit's green LED. Ten minutes and done ...
Cheers,
Ross McKenzie
Melbourne Australia
Jul 24, 2011. 2:48 AMasorton says:
I want to hack the unit so it works with the PIR but does not spray eery half hour when nobody is about, can this be done?
Jun 15, 2011. 11:50 AMlegoman44 says:
Hi,
Not exactly sure why you drilled holes through the PCB for the jumpers. Could you not jumper the points from the other side of the board and not drill?
Jun 16, 2011. 3:28 AMR.A.T.M says:
ya i dont see the point to drill other than neat ness
Nov 21, 2011. 8:56 PMDIY-Guy says:
I like neatness, but my worktable is a pile of projects without visible order to the untrained eye.
Jun 15, 2011. 10:47 PMR.A.T.M says:
could you hook the black one to a mortor and whit to power sours and can you chang the timming so it go off evrtime that it senses moten
Mar 15, 2011. 9:41 PMPatYoungers says:
I put this small circuit to use as an IR activated nightlight.
Jun 8, 2011. 12:52 PMlegoman44 says:
Regarding your circuit, can you be more specific on the mosfets you used (depletion zone/enhancment zone). Why are you using a pfet and nfet? could you not use two nfets?
Jun 9, 2011. 6:17 PMPatYoungers says:
The P-channel is a Vishay Si4413ADY power FET enhancement mode device.
The N-channel is a Supertex TD9944 dual FET enhancement mode device.
This circuit does not require special FETs to work, just some that are good enough since this is not a power amp or a radio. I had "easy access" to these so I used them.
Both are surface mount packages and require good eyes or a microscope to handle. At 50+ yrs old, I had to use a microscope. I'll use vacuum tubes next time.
Have a look at the schematic at the link in my original post above to go with this explanation.
An N-Channel FET would not work for the first stage when driven by the SD signal because the logic is inverted. That is, the SD signal is at 4.5v when not activated. So you need a transistor that will be off when the gate and source are at 4.5v. So I used a P-channel FET. When iMotion circuit is activated, the SD signal drops to about zero volts, turning on the P-Channel FET. That charges the capacitor up to 4.5v, which in then turns on the N-channel FET, lighting up the LEDs. When the iMotion stops sensing the IR disturbances, the SD signal returns to 4.5v and the N-Channel FET turns off. This allows the 100K resistor to slowly discharge the capacitor which slowly turns off the N-channel FET reducing the current through the LEDs and making them slowly fade out. When the voltage on the capacitor reaches something less than 0.5 volts, the N-channel FET and the LEDs are basically off.
That's a bit more than what you asked, but I was on a roll so I kept typing. I really need to turn this into an instructable.
May 26, 2011. 9:40 PMhoonflap says:
just to verify, the digital signal available after completing step 3 is a solid 5v, correct? or 4.5ish, i see 3 AA's? i want to trigger a 5v reed relay. would i need any additional steps?
Jan 31, 2011. 2:31 AMAnnoymous says:
They Suck i know people that have them. Not this type but they have the Freshmatic and Straight Freshmatic Mini and they get sprayed in the face all day.
Nov 4, 2010. 11:37 AMkelceysyoung says:
What is the point of this? I mean it looks really neat but i'm not sure if i understand the point.
Jan 30, 2011. 2:54 AMsillywilly says:
Sorry someone didn't respond to your question sooner kelceysyoung! You can use this modified/repurposed PIR to trigger several projects but the best one is one member KipKay did with another PIR and a miniture DVR camera to take pictures when warm body moves into view i.e. as a game camera, snoop on a unknown nanny, (or any other person who deserves it), use it to catch that bad neighbor in the act, or perhaps to find out info on who has been breaking in?
Sep 30, 2010. 9:07 AMuberdum05 says:
You can just use a small flat-headed screwdriver (the ones that look like this "--" on the end") and just wedge it in between the two points of the triangle on the screw :)
Jan 11, 2011. 11:40 AMJohnZoidberg says:
I've found that the tip of one side of a pair of needle nose pliers sometimes works as well
Jan 12, 2011. 11:58 AMuberdum05 says:
I suppose it would work quite well if the head is quite large
Oct 29, 2010. 5:26 AMComputothought says:
Hmm mine looked complete different inside, but it did have the pir. Mine was wall powered and had two boards. The board with the pir had 3 wires coming off of it. the power supply was in the other board. There was no motor inside also. Maybe I can get a schematic from the fcc if I can numbers off the board. I am amateur at this.
Nov 4, 2010. 9:18 AMComputothought says:
I could not find the one you had. It said imotion on the box. There was a different one a another store but it was near $20 dollars. I passed on it.
Nov 4, 2010. 8:59 PMComputothought says:
I think I finally found the right one at Target. That product was not at Walmart or Walgreens when I first looked. I went over to Walmart for something else and saw they finally had it back in stock. Target was a dollar cheaper than Walmart. Thank you for your patience.
Sep 24, 2010. 3:27 PMsnander says:
Woohoo! On sale right now for $3.99 each at Walgreens.
Sep 30, 2010. 8:31 AMSovereignty says:
My wife comes home with the electric air-fresheners [all brands] for under a dollar each, sometimes free; sometimes the stores are paying her to leave with them. She's also been treating me to bottles and bottles of Scrubbing Bubbles with the auto-triggers, and a few other products [same manufacturer] that have the same 1.5v pumps; for pocket change! The battery included is worth more alone than what she ends up paying. Oh! And more recently, the bug repellent clip-ons. I've thought of a few clever uses for those, but this stuff is coming to me at exponential rates! I almost forgot to mention the free battery powered razors...with the cute little clippers on the end... ... ...and it's waterproof! Oh dear!
Them crazy couponing folk are real; and they ain't all that crazy. I'm married to one. Like the l337 to the n00bz, she scoffs when people mention their 25, 30, 50 percent savings. She's to the point where she spends very little time doing the prep-work. She has fun doing it, anyway-- 'cept when Walgreens gives her a hard time. She loathes Walgreens. Well, I'm sure there're more than one coupon -ibles out there.
Oh, thanks for the -ible, Doug.
Sep 30, 2010. 8:45 PMtbcross says:
you know I am a deal hound myself, I feed 3 very very tall teenagers and myself and all the scraps the dogs and cats munch on every month for less than $400, but oddly enough though I never use coupons! I would like to, but it just seems like too much. Maybe you could get your wife to part with her coupon-ing secrets for an ible??
Oct 1, 2010. 11:19 AMSovereignty says:
No secret in it, really; she went to the Southern Savers website ['cause we're in Tampa] they had tutorials that she read through, and after a while she learned those basics by heart. She checks the fliers, collects the coupons, save the store 'rewards', etc. The only difference you'll have is by region [and I'm sure there're coupon sites dedicated to most popular regions in the US...or abroad] The entire process would be tedious but the lady on that website mentioned does alot of the footwork for you, finding the deals and such, so it'll only benefit those of us in the south-east region.
And of course, depending on an 'INDIVIDUAL' store policy [yeah, right], you may or may not have MMA matches with store managers, fist-a-cuffs with crotchitty old bats, or be incarcerated for putting your fist down an obnoxious teenie boppers throat. Prepare to be treated like a criminal when you leave some of these stores; but then you'll know you're doing it properly [and legally]. Here's a hint though, my wife always says she'll choose a teen boy cashier when in doubt. To quote her, "...they just don't give a crap..."
Jan 26, 2011. 5:10 PMtbcross says:
haha I have actually noticed the teen boy phenomenon after a Thanksgiving turkey markdown at wally world, the elderly lady that checked me out turned something that should have been a few seconds in duration, into an investigation that took half an hour despite the clear print on the flyer! I swore off any line at the Mega store that wasn't headed by someone who routinely used OMG and BFF in conversation!!
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
31
Author:Doug Paradis
