Introduction: Re-skinning a Rebab
Picture of Re-skinning a Rebab
A rebab is a two-stringed fiddle and a member of the Javanese gamelan orchestra.
I am a member of Ireland's National Concert Hall Gamelan orchestra. Our rebab's skin split during transport to a gig, even with the strings loosened and the bridge collapsed ...these things happen which is why it is important to learn how to repair them!
Step 1: Equipment
Picture of Equipment
For the project you will need:
A replacement skin
A trusted pocket knife
A basin of tepid water
Wood glue
Pins/cocktail sticks
Sandpaper
A damp cloth
PVC tape
All told, the project takes about an hour.
Step 2: Undressing the Rebab
Picture of Undressing the Rebab
One of the biggest challenges was undressing the body of the rehab. As you can see from the first photograph the neck/head comes of very easily, once unstrung. After much inspection and gazing in and around the remaining parts of the rebab, we were certain that the two pieces of turned wood were glued onto the metal rod which connects them through the body of the rebab. However, a stern yanking revealed how it was held together [see pictures].
Once the pieces of turned wood, lets call them the tail piece and the collar for all intents and purposes, and the metal rod were removed, the decorative cloth slipped right off.
After those components are removed it's time to tear off the old skin.
Step 3: Prepping the Body
Picture of Prepping the Body
Thoroughly clear the body of its old skin. Pay particular attention to the sides.
There will be residue left; a mix of skin and glue. In order for the new skin to adhere properly to the body a clean surface is necessary. Using a fine/medium grade sand paper you can erase all the residue. Run you finger along the edges to find any rough spots - such areas MUST be smoothened down as the skin will be stretched tightly over the edge; bumps, splinters, etc., may cause tears. Take your time with this.
Step 4: Soaking the Skin
Picture of Soaking the Skin
Allow at least 10 minutes for the skin to soak. In retrospect I would soak it for longer as the skin dries so quickly, leaving you with less time to work with it when it is wet and pliable. I used a clean baking tray to drown the skin. I reckon tepid water helps to further saturate the skin than cold water, however hot water may damage it.
Step 5: Putting on the New Skin
Picture of Putting on the New Skin
Line about an 2-3cms of the outside rim with wood glue or an alternative adhesive. I found that the glue dries quite quickly so next time I would water it down slightly to allow more time to work with the skin.
Remove the skin from the basin and pat away/shake off excess water. Place it on the body as symmetrically as possible.
Using the existing holes (pictured in the first photograph) pin down the skin. Pin linearly to build up the tension evenly (see second photograph).
When wet the skin is very pliable. Don't be afraid to really pull it taut, the skin can take it (within reason, of course!). As the skin dries it tightens and the tension increases considerably so don't worry if you think the skin is not taut enough - just try to keep the tension even.
Once pinned down allow the skin to dry naturally. Rub the skin to help it stick to the body and for the edges of the skin to become as close as possible to the wood.
It dries very quickly but always allow for "extra drying time" so that you are confident everything is bone dry before reassembly.
Step 6: Reassembly
Picture of Reassembly
The skin adhered well to the body and I was delighted with the tension. The race against the drying time of the glue an the skin meant that I had to compromise a little - the edges of the skin were not very neat. I took two steps to amend this:
- I trimmed the bits that were not glued down (when the skin dried it dried stiff, attempting to glue the stiff parts down would be a fruitless endeavour).
- I used PVC tape (electrical tape or any tape which can be manipulated - i.e. not sellotape/parcel tape - will also work) to cover where the edge of the skin meets the wood.
My rational for this was that I was worried that the decorative garments might catch on the loose/raised edges/folds in the skin thus tearing it or lifting the skin further from the wood causing damage to the skin.
The garments go on first and then slot the rod through the body with the collar still attached. Once slotted through from the top to the bottom, shimmy the tail piece onto the rod.
Placing something soft on the ground, like a cushion or bunched up towel, lower the collar to the floor. The soft item allows you to push the tailpiece securely onto the rod and tightly onto the body with out damaging the beautifully turned wood of the collar. Once you are happy that you have tightly secured all parts, your job is complete!
Now time to attach the neck and restring the rebab!
Happy music making!!
mdbarchas01 (author)2017-02-24
Why did you use the image with the pug in it? Does it not distract attention to the actual focus ?
Anika Babel (author)mdbarchas012017-02-24
She invited herself into the photograph. How would she distract? Does her inculpable curiosity not embody what this site is all about?
Swansong (author)2017-02-22
That's neat, I've never seen one of those before! I'm glad you could fix it :)
Anika Babel (author)Swansong2017-02-22
Thank you! :D
About This Instructable
6,810views
6favorites
License:
Bio: Musicker
More by Anika Babel:Re-skinning a Rebab
Add instructable to:
