Read Only Memory
415
10
Posted
Introduction: Read Only Memory
A ROM is a combinational component for storing data. The data might be a truth table or the data might be the control words for a microprogrammed CPU. A ROM that implements two functions does not require twice the number of gates as a ROM that implements one function. (The decoder is shared by every output function.)
we will design Read only memory using the circuits cloud simulator
http://circuits-cloud.com/
if you does not used the circuits-cloud before, you can see this intractable:
https://www.instructables.com/id/Circuits-Cloud/
Step 1: The ROM Design
Because it is 16*8 ROM, it needs:
- 4 digital inputs
- 8 leds ( as output )
So, drag and drop the components from the digital components panel and connect them
Step 2: Store the Value in ROM Locations
1. Double click in ROM parameter.
2. write an 8-bit value in each location of ROM.
3. click on ( save parameter)
Step 3: Saving and Running the Circuit
save your circuit then running it.
check the output value in each address (location):
if input ( A0, A1, A2, A3 ) =
0000 , output = the value stored in location 0
1000 , output = the value stored in location 1
0100 , output = the value stored in location 2
1100 , output = the value stored in location 3
0010 , output = the value stored in location 4
and so on.
- you can check the circuit:
http://circuits-cloud.com/circuit/details/gdd1FJeK...
- also you can see how the circuit works.. in this video
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
  • Sew Warm Contest 2018
2 Comments
An eight x eight ROM contains 8 words with 8 bits in each word. Addressing 8 locations takes only 3 bits, A0, A1 and A2. Why does your ROM require 4 address bits?
Thank you.
I already sent them a message via email
circuitscloud1@gmail.com
They will fix it , and I will update it as soon as possible.
