Read and Write From Serial Port With Raspberry Pi
389,686
260
34
Published
Introduction: Read and Write From Serial Port With Raspberry Pi
In this tutorial we will see how to use the serial port on Raspberry Pi. We will use the serial port available on Raspberry with a RS232/TTL 3-5,5V adapter and a USB-serial adapter. By default the Raspberry Pi’s serial port is configured to be used for console input/output. This can help to fix problems during boot, or to log in to the Pi if the video and network are not available.
To be able to use the serial port to connect and talk to other devices (e.g. a modem a printer.. ), the serial port console login needs to be disabled.
Here we use Raspberry Pi 2, and we connect a RS232/TTL 3-5,5V adapter to pins 4 (5V), 6 (GND) ,8 (TX),10 (RX) of Raspberry, obviously connect tx with rx and vice versa.
Emmeshop tutorial Raspberry serial connection
To search for available serial ports we use the command
dmesg | grep tty
The output is something like this
pi@raspberrypi ~ $ dmesg | grep tty
  [    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa01041 bcm2709.serial=0x93f9c7f9 smsc95xx.macaddr=B8:27:EB:F9:C7:F9 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=tty1 console=ttyAMA0,115200 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
  [    0.001774] console [tty1] enabled
  [    0.749509] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev3
  [    1.268971] console [ttyAMA0] enabled
  pi@raspberrypi ~ $
Last line indicates that the console is enabled on the serial port ttyAMA0, so we disable it
Run the configuration command and follow the instructions below
sudo raspi-config
Reboot and try with
dmesg | grep tty
output now is
  [    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa01041 bcm2709.serial=0x93f9c7f9 smsc95xx.macaddr=B8:27:EB:F9:C7:F9 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
  [    0.001769] console [tty1] enabled
  [    0.749438] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev3
  pi@raspberrypi ~ $
Now we can use the serial ttyAMA0. We connect an adapter usb / serial, then we will try to establish a communication between the two serial ports; obviously in a practical application to every serial we could connect a device, for example a modem, a printer a RFID reader etc.
Emmeshop tutorial Raspberry two serial port communication
After connecting the second serial port we launch the command to find the name that Raspberry gives him
dmesg | grep tty
  [  971.919417] usb 1-1.2: pl2303 converter now attached to ttyUSB0
  pi@raspberrypi ~ $
Ok, now we create two files, one who writes something on the ttyAMA0 port and the other that reads on the ttyUSB0 port.
serial_write.py
    #!/usr/bin/env python
           import time
           import serial
           ser = serial.Serial(
               port='/dev/ttyAMA0',
               baudrate = 9600,
               parity=serial.PARITY_NONE,
               stopbits=serial.STOPBITS_ONE,
               bytesize=serial.EIGHTBITS,
               timeout=1
           counter=0
           while 1:
               ser.write('Write counter: %d \n'%(counter))
               time.sleep(1)
               counter += 1
serial_read.py
           import time
           import serial
               port='/dev/ttyUSB0',
               baudrate = 9600,
               timeout=1
           counter=0
           while 1:
               x=ser.readline()
               print x
If we run both files, serial_read.py will read what serial_write.py writes
Emmeshop tutorial Raspberry serial write and read
This is just a small example but it can serve as a starting point to send a print to an old printer or read data from a router or a gps.
Follow us on social to stay informed.
http://www.emmeshop.eu
3 People Made This Project!
  • Water Contest
    Water Contest
  • Creative Misuse Contest
  • Oil Contest
    Oil Contest
34 Discussions
There is an error, you can't "write" a data if you don't add .encode()
ser.write(str(10).encode())
Set it up communicating but the output is garbled. The language of the rpi2 is english, character enconde utf8, baud rate 9600, stop bits one, eight bits data. Any hints?
Just figured it out. It's because I didn't connect a the ground on the pins.
Did you find a solution to this? I am having the same problem.
So I run both programs at once, but serial_read.py does not give me the Write counter like it should. Any thoughts on why that is? Help would be appreciated. Also if its really simple, I'm a noob XD
1 more answer
Never mind I was being stupid I got it
AmitP103
Question 4 months ago
Hello. Firstly let me thank you for this great tutorial. I have followed the exact same procedure as given above. I have used an FTDI chip to connect between raspberry pi. On the sender side the port name id /dev/ttyAMA0 and on the receiving side it is ttyUSB0. However when i run the code of serial_write the code gets stuck at ser.write() line and on the receiving side only space and newline are getting printed. What does this mean? Why am I getting such error? Help plzzzz. Thanks in advance
hello guys i m trying to connect arduino and raspberry pi3 via HC-05 bluetooth communication .
i had done the pairing with pi. but when i am executing serial code to send data to pi its print ? on pi terminal. please help me out .
thanks
Thank you for your help.
I used serial communication for a industrial thermal printer.
I am a noob sorry,
Where to make the files on raspberry pi 3 ?
Many thanks for this ... Ive upgraded my Raspberry Pi and it must have set /dev/ttyAMA0 for console use .. Now its all working again! ;-)))
i work directly on a raspberry pi zero, and when i try to run the program and test the serial communication the time library is missing ans the program wont execute. Do you have any idea how to solve that?
thanks
I'm using HC-05 Bluetooth module with RPi3 through UART to receive data from other bluetooth module.
What I have to replace ttyUSB0 in port='/dev/ttyUSB0' in order to read serial data.
I'm working on this to try and get it to work, but ttyAMA0 disappeared after disabling serial.
I'm not sure if it's a problem with raspi-config GUI or not, I ended up undoing that and doing the following, though I'm not entirely sure if step 2 is necessary:
1. Changed code to use /dev/tty1
2. (from stack exchange)
" step 5 -
a)to disable the Serial Console edit the file using
sudo nano /boot/cmdline.txt
remove the word phase "console=serial0,115200" or "console=ttyAMA0,115200"
Exit and save your changes "
Then 'Sudo Reboot'
I'm having the same problem, I disabled and now ttyAMA0 is gone. Did you figure out what was wrong?
btw, uname -a returns
Linux raspberrypi 4.4.26+ #915 Thu Oct 20 17:02:14 BST 2016 armv6l GNU/Linux
