Introduction: Read Temperature With DS18B20 | Raspberry Pi 2
Hello!
This is my first instructable project, so it won't be as professional as others!
We are using DS18B20 temperature sensor to get the temperature of your room.
Enjoy!
Step 1: Supply
You will need:
The sensor itself DS18B20
http://www.ebay.com/itm/Waterproof-Digital-Thermal...
Resistor (I'm using 4,7k Ohm)
Because of the picture is blurry the color codes are: yellow,violet,red,gold
Jumper wires
You can find the resistor and the jumper wires online, or in your local electronics store.
Step 2: Wire It UP!
The wiring is very simple.
I got the drawn picture from https://learn.adafruit.com/downloads/pdf/adafruits...
Connect the 3.3V (red) from the sensor to the 3.3V rail on your raspberry pi
Connect the GND(black) to the GND rail on your raspberry pi
Connect the Data(yellow) to a pin on the raspberry pi
Connect your resistor with the 3.3v and the Data as shown in the drawn picture
!!!!WARNING!!!!
IT MUST BE ON THE PIN 7 - GPIO04(GPIO_GCLK)
THE BEGINNING OF THE RESISTOR MUST BE ON THE 3.3V (yellow front)
Step 3: Now the Coding! Without It the Sensor Is Just a Piece of Wire.
Turn on your raspberry pi and let's begin.
First step:
First we need to config a file.
Do that by typing: sudo nano /boot/config.txt
This file let's you config your booting.
Here you search for dtoverlay
When you have found it just correct it to:dtoverlay=w1-gpio
Type sudo reboot, to reboot your device
Second step:
Type:
sudo modprobe w1-gpio && sudo modprobe w1_therm
ls -l /sys/bus/w1/devices/
cat /sys/bus/w1/devices/28-000006dfa76c/w1_slave
!!!WARNING!!!
My sensor is 28-000006dfa76c yours may be different, so just replace it!
Third step:
I will attach a file that contains the temp.py
!!!WARNING!!!
Replace the sensor is in the code with nano temp.py
Step 4: ENJOY!
Just type sudo python temp.py to run your code.
Open a beer and celebrate while you get the information about how warm or cold it is in your room.
If you have any question, please leave them below!
Cheers!
(it's 25 in my house at the moment)
