Unlike Through hole resisors which use colored bands to determine the value, surface mount resistor have numbers and sometimes letters. I will teach you how to take those letters and digits and determine the value.
Looking at the image you see 4 resistors, the first being 391 the seconed 270 and the two at the bottom are the same 30R9. That does not stand for a 391 ohm , 270 ohm, and so on. The formula for breaking the code down is as follows.
1st value-2nd value-multiplier
3 9 1 = 390 ohm resistor
2 7 0 = 27 ohm resistor
2 3 3 = 23000 ohm or 23K ohm resistor
There are some resistors which have 4 digits. The formula is the same with the addition to a digit.
1st value-2nd value-third value-multiplier
2 3 5 3 = 235K ohm resistor
You may ask"why some have three diigits and some have four?" three digits typically means that the resistor is 5% tolerance the four digit typically means the resistor is 1% tolerance. If a letter is used to represent tolerance use the chart below.
B=.1%
C=.25%
D=.5%
F=1%
G=2%
J=5%
K=10%
M=20%
Z=80%
Now you will notice that the last two resistor have an "R" in the equation. The way to look at these is very simple. The R represents a decimal. So 30R9 is a 30.9Ohm resistor.
R23= .23 ohm
5R6= 5.6 ohm
45R3= 45.3 ohm
Of course you can read the values with a meter, but whats the fun in that? I hope you all learned something from this little write up.
B=.1%
C=.25%
D=.5%
F=1%
G=2%
J=5%
K=10%
M=20%
Z=80%
R23= .23 ohm
5R6= 5.6 ohm
45R3= 45.3 ohm
<p>I have 2EE resistor, what is the value of that? please help me... thanks a lot...</p>
<p>I have these capacitors out of an A/V Reciever with markings K3 47 16v. Can someone tell me the meaning and how I could purchase 10 of them. This is my first major task.Thank you for your time</p>
<p>Those are SMD aluminium electrolytic capacitors, the K3 is a series number, 47uf 16V.</p><p>You should be able to find what you need here-</p><p>http://www.digikey.com/product-search/en/capacitors/aluminum-capacitors/131081?k=47uf%2016V%20capacitor</p>
<p>I would like to say Thank you for taking the time to Help me out. I do Appreciate</p>
<p>Hi, What about the underlined SMD resistor like 304 and 332. I mean ___.</p>
what would be resistor ohm value if a resistor indicate only 'D' letter and also what is for very lite colour srd resistor with out any digit.
What if you have some without any markings at all? <br>
<p>Maybe uUse a volt-ohm meter to determine it's resistance?</p>
<p>That is a 100% clear explanation!</p><p>Simple but effective.</p><p>Thanks</p>
<p>Excellent explanation of SMD Values. </p><p>As a newbie to SMD I have found myself a little daunted by this miniature hardware, but I am now more confident of installing the correct resistor when constructing my projects.</p><p>Lance</p><p>- I now have a (cheap) bulk lot of mixed SMD on the way to practice my soldering skills -</p>
<p>Hi Instructables, I have looked up many sites to find the best explanation on SMD resistor colour codes. Your one is excellent. I will recommend this explanation to everyone who is searching for a good basic understanding.</p><p>Dave.</p>
<p>Can i use that usual resistor with color coding instead of SMD resistor of same value(ohms) in a project ????</p>
hi,i am neeraj i m joining a new member in ur electronic world. plz.help me.
Here's the full link. The part after and including the last % is not needed. <br> <br>http://www.te.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Data+Sheet%7F1773204%7FH%7Fpdf%7FEnglish%7FENG_DS_1773204_H.pdf <br> <br>Hope this helps.
There is a completely different code used on some resistors. It has to do with a three number scheme that allows 1% values. I found a good reference here: <br> <br>http://www.te.com/commerce/DocumentDelivery/DDEController?Action=showdoc&DocId=Data+Sheet%7F1773204%7FH%7Fpdf%7FEnglish%7FENG_DS_1773204_H.pdf%7F1622827-1 <br>
I like to put the surface mount resistor on a hard surface then smash it open with a rock. Then like reading tea leaves I divine what it's resistance once was ...
Pfred i gather from this post ,and others, that you aren't a fan om SMD. :0)
Should I be? When I strip boards with SMD on them I just let those parts float on the top of my solder pot until I skim it. So when I say SMT stinks I mean it literally!
!!! "Perfect" !!! <br> <br>Exactly what ive been wanting to know to get into SMD soldering !! <br> <br>Thanks a bunch for taking the time to make this nice and simple 'ible so a complete beginner (started this year!) in electronics can easily digest ! <br> <br>Keep up the GREAT work and hopefully some more write-ups on SMD's ! <br> <br>Oh by the way, how would i measure the capacitance of a SMD capacitor using a DMM ?? <br>many thanks in advance fo a noob question but my friend google hasnt turned up much, or maybe im not searching for the right thing here, lol !!!
